With Emplode/JEmplode and no Hijack, you can't (or shouldn't be able to, at least)
  • write to the kernel area of flash
  • change the running order (e.g. HTTP "play")
  • remove or replace files outside of the music partions (e.g. the player binary), other than config.ini
Any attempts on the player are obvious when the music stops and an unasked-for synchronize begins.
Adding a wide-open Hijack does make me (even more) nervous.
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
