If you need a drive letter (for running a program you are out of luck
If you need a shortcut to a share on another computer then create a shortcut. Try the following:
1) Make a shortcut to a file on your local harddrive
2) Edit the properties of the created shortcut, and replace the filename with \\ip-adr\share
3) rename the shortcut to whatever you want
Best regards
Ole
