I just had this happen to me on Beta 10, and it's happened to me in the past (around 8c I believe)...
Sometimes after a reboot, the unit plays in slow-motion with stuttering audio, as if something was grabbing all the CPU cycles away from the player/vis software.
Interestingly enough, all of the times it's happened to me, I'm pretty sure it was running one of those cloudy-looking visuals: Grampian, Hercynian, or Caledonian. Maybe it's related to the vis code? I've seen other people report the bug- were you all running the same vis when it happened?
It's very intermittent (I've only had it happen three times in three months), and I don't now how to induce the bug. This last time, it happened when the unit did a quick-reboot because of the voltage drop when I started the car.
Empeg #144
