Yeah I know. I'm just saying that originally the busybox telnet daemon would run /bin/login to do the username and password checking then finally run the shell.
I would write a empeg specific login. Or I could change the telnet daemon to do the authentication itself. Not sure.
Okay, it's not optimal about disk access but if I just make it read config.ini each time it receives a connection then it shouldn't have to worry about problems with accessing config.ini. Or it could cache the password the first time it's needed. This last option could be confusing for users though.
- Trevor
