Agreed, it just depends on what you want to do. The sled press fits into place tightly enough that it's not going to move much if at all. But I like everything to be bullet proof - I put a lot of work into something to make sure I don't need to work on it again, hence I had a few tack welds made.
Mounting it through th front is fine too, some people have done that. It protrudes from the face a little, but not too badly. But I wanted it to be flush, that was my top priority there, so I had to cut the sides out a little. Again neither is better or worse, just depends on what you want to do. Your method is perfect for you and will be for others. Just not me
Congratulations on your Eclipse and empeg!
