Quote:Sounds more like something is wired wrong rather than an amperage issue
I would think the same thing, (and it may be) but this seems to be a common problem with the 3000gt. The power lead is hooked up to the stock power lead and the ground checks out with the multimeter. I'm by no means an expert, but how would you explain no voltage drop with the player turning off momentaraly? And then reading a voltage drop (with the headlights comming on) and the player stays on. This is way over my head.
30 Gig #010101805 No other mods....yet.
