I've checked through the FAQ and couldn't find answers to these two, so...
1. Is it possible to use the (press-and-hold) down button to switch between two Info modes instead of between Info and Visualization modes? I'd like an easy way to go from Track to Now&Next info modes, and I don't care about Visualizations that much.
2. When I use a Wendy filter to remove certain songs from a playlist, the total number of songs in the playlist decreases as it should. However, if I turn the filter off the number doesn't increase back to the unfiltered number. The only way I've found to restore filtered songs to a playlist is to start the playlist over. Is this normal, and is there an easier way to return a playlist to normal after using a filter?
Thanks for any help.
