Right.
Outer sleeve = RCA grounds (common).
Tip and Ring = Left and right positive.
Don't know which is which for the tip and ring, though. Anyone?
Also, you might want to have a defeatable chassis ground on the sleeve to compensate for different ground loop issues depending on what device is plugged into the jack.
