Not that the electronics in the DeLorean have always been known to be first rate or anything, but it's a little annoying when you can't listen to a song all the way through without the empeg cutting out.
I'm sure a lot of the problem is low voltage due to the wimpy, 20 year old alternator, but just to be sure, I think I'm going to wire the power directly to the battery.
What gauge wire should be used to do this, and what amperage inline fuse should be used?
Thanks in advance.
