r3mix is out of date...
MusicMatch with 192kps will give you good results. But if you want to step up, I recommend using AudioGrabber or Exact Audio Copy (if you have Win2K). Both are really good - EAC is free but a little harder to learn. I like EAC because it is great with scratched disks too.
Either way, use LAME encoding. The latest version of LAME is optimized to use the "-alt present standard" setting. Do a search on LAME or Audiograbber.
PS - Sensai is the master, not the student.
Brad B.
