Hmm. Good point. I forgot about the protected bootloader.
So if you wanted to replace your flash then you'd need to download the bootloader from another empeg, flash it into the new chip, unsolder the old chip, solder in the new one and finally flash the new kernel. I think the easiest option is to not wear out your flash
- Trevor
