#104575 - 11/07/2002 14:02 Help with XML
lectric
Loc: New Orleans, LA
Whenever I go to the playlists option in the XML proggie, I get this: EEEEEE FFFFFF ?fid=&ext=.m3u ?NODATA&SERIAL=%23
Any ideas? everything else works fine.
#104576 - 11/07/2002 14:17 Re: Help with XML [Re: lectric]
lectric
btw, when I do a rwm, I get an error stating:
mount: can't find /drive1 in /etc/fstab or /etc/mtab
is this related, perhaps?
#104577 - 11/07/2002 23:47 Re: Help with XML [Re: lectric]
mtempsch
Do you have a single or dual drive empeg?
If dual drive, you might want to add a line to /etc/fstab about /drive1. Pattern it off the /drive0 line, but replace "hda" with "hdc".
Otherwise I believe, from what I remember of the rwm script, the message is harmless / expected.
#104578 - 12/07/2002 01:51 Re: Help with XML [Re: mtempsch]
Yeah, the stock install doesn't have a line about /drive1 in /etc/fstab. Not sure why.
#104579 - 12/07/2002 04:38 Re: Help with XML [Re: Roger]
Why do I never get an error message when I do RWM on my dual-drive player then?
#104580 - 12/07/2002 05:50 Re: Help with XML [Re: tfabris]
Because it looks in /proc/mounts first. It's only if you've managed to completely unmount the disk that rwm will fail to remount it read-write.
#104581 - 12/07/2002 06:28 Re: Help with XML [Re: lectric]
Ezekiel
Loc: NH USA
I got that until I applied MSXML3SP2setup.exe - the second service pack to XML3 (assuming you've got a windows box). HTH.
http://www.microsoft.com/downloads/release.asp?ReleaseID=32833&area=search&ordinal=3
-Zeke
WWFSMD?
#104582 - 12/07/2002 07:09 Re: Help with XML [Re: Ezekiel]
lectric
Thanks all.. I was thinking about editing the fstab, but I'm not quite that confident in Linux yet. (Wasn't sure exactly what would happen) Getting there, but not quite.
And oops on the parser, for some reason I skimmed right over that.
Edited by lectric (12/07/2002 07:10)
