#107877 - 28/07/2002 12:22 Two Head Units Install Diagram - Comments Anyone?
Caps
Loc: Arizona, USA
I have been looking at the electronics in my car all morning, and I think that I have come up with a plan that will connect it. I am attempting to connect my existing radio/tape player that is in the car now as a slave to the empeg.
The issues I had are that there are 8 wires going out to the speakers now, but the empeg only can handle 2 wires in. Plus I am not sure about the AUX input ground(22), I will have to look through the FAQ to see if it goes to the normal ground on the radio or what.
And do I need to use the Telephone mute wire? I don't even have a cell phone, and my car doesn't have a place for it.
Another question is whether there will be enough power on the headlight sense and ignition sense lines if it is split. I am pretty sure there should be, but I just want to be sure.
You can find the image here:
http://www.public.asu.edu/~rcappo/Wiring_Diagram.jpg
Thanks for all your help.
#107878 - 28/07/2002 12:26 Re: Two Head Units Install Diagram - Comments Anyone? [Re: Caps]
According to your wiring diagram, your head unit has speaker outputs rather than RCA line-level outputs.
Do not connect speaker outputs to line-level inputs. The empeg does not have speaker-level inputs.
You can purchase a speaker-level-to-line-level converter box and then this would work. Note that you only need one of the ouput pairs from the head unit (either the front pair or the rear pair).
#107879 - 28/07/2002 12:29 Re: Two Head Units Install Diagram - Comments Anyone? [Re: tfabris]
Other than that, the diagram looks correct.
Well, except for the fact that you show six speakers coming off of a four-channel amplifier, but I won't get into that.
#107880 - 28/07/2002 13:11 Re: Two Head Units Install Diagram - Comments Anyone? [Re: tfabris]
Caps
Loc: Arizona, USA
Thanks!
It's the little stuff like that that I'm worried about.
I know about the 6 speakers, I will figure a way to hook them up to the amp when I get to that part.
I think you saved me a lot of time and headaches attempting how to fix that problem.
#107881 - 30/07/2002 02:01 Re: Two Head Units Install Diagram - Comments Anyone? [Re: Caps]
thinfourth2
Okay six speakers four channels will go providing you have one set of full range speakers (e,g decent pair of 6 by 9s with built in tweeter) and a set of woofers or mids Not sub woofers and a set of crossovers and a set of tweeters.
The full range speakers would go to the rear of the car and then the tweeters and mids/woofers would go to the front of the car.
Just to repeat what tony said don't put speaker outputs into empeg you may toast it
