#11107 - 09/07/2000 09:53 phone mute nogo
jfranke
I have just conencted my handfree to the mk2 for mute, it doesn't work. Is that feature implemented yet ?
Tx, J.
#11108 - 09/07/2000 10:34 Re: phone mute nogo [Re: jfranke]
Not implemented yet - it will be soon.
#11109 - 09/07/2000 14:20 Re: phone mute nogo [Re: altman]
jfranke
TX. Will that sense for 12 or 0V ? Thanks, J.
#11110 - 09/07/2000 15:02 Re: phone mute nogo [Re: jfranke]
12v=mute, 0v=normal.
#11111 - 09/07/2000 19:20 Re: phone mute nogo [Re: altman]
tadzio
Loc: Munich. Germany
Is that how all the other devices work? The (admittedly few) units I know use open/12V = normal and ground/0V = mute. If that's standard (which I'm not really sure about, but at least I thought so - this requires some more investigation), then the empeg should adhere to that standard.
Daniel
--- "I love deadlines. I love the WHOOSHing noise they make as they go by." - Douglas Adams
#11112 - 10/07/2000 02:06 Re: phone mute nogo [Re: tadzio]
Cambscar
Loc: Cambridge, UK
Most UK kits use ground=mute. The vast majority of the kits we see are Nokia, and they definitely work that way.
Dominic
Cambridge Car Audio
http://www.cambscaraudio.co.uk
#11113 - 10/07/2000 03:30 Re: phone mute nogo [Re: Cambscar]
Dominic,
Do they generally use open circuit or 12V for the non-mute state?
#11114 - 10/07/2000 05:50 Re: phone mute nogo [Re: rob]
Cambscar
Loc: Cambridge, UK
Hmm, now you're asking....
I'm pretty sure it's +12. If you mail me at work, I'll look into it tomorrow AM when I'm back there.
Dominic
Cambridge Car Audio
#11115 - 10/07/2000 08:04 Re: phone mute nogo [Re: rob]
TommyE
Loc: NORWAY
When I made my PIC muter for my Nokia 6110 (original Nokia handsfreekit)
Ground = mute, Open (no 12v) = unmute.
TommyE
#11116 - 10/07/2000 08:06 Re: phone mute nogo [Re: Cambscar]
jfranke
I installed just a Motorola timeport handsfree and this is sending 12V out on the mute wire (so it would work with the empeg), and nothing when not in a call.
That mostlikely is the standard I think. Otherwise, if there would be nothing connected to the mute wire on the car stereo, it would be always in mute which doesnt make sense.
Anyways, I have just installed another Philips Carin navigation system, and there you can select if you would like to use 12V or 0 V for mute. J.
#11117 - 10/07/2000 10:18 Re: phone mute nogo [Re: jfranke]
Cambscar
Loc: Cambridge, UK
The vast majority of aftermarket radios look for a ground to phone mute. There are a few exceptions like Alpine and VDO, that allow for either. The OEM stuff that does have mute facility also tends to be ground signalled - VW, Audi, etc.
Dominic
Cambridge Car Audio
#11118 - 10/07/2000 10:24 Re: phone mute nogo [Re: Cambscar]
This functionality will be configurable - either 0V or 12V mute. It won't work with open circuit signalling though. A pull up resistor would be needed in this instance.
