#118496 - 30/09/2002 09:01 My Rio hangs when using Pioneer remote
mpelaz
Hi again
Last week I uploaded a new config.ini to make Riocar work with my Pioneer wheel remote. I appended to my config.ini the remote section that appears as an example at the bottom of http://empeg-hijack.sourceforge.net/ir_translate.html only changing the volume buttons (A to B) since it went down when pushing up...
When a new song plays,, empeg seems to be very busy, the volume knob doesn't work fine... and if in that moment I push 'volume up' button several times, empeg hangs up. I have to take it off the car, and plug it again.
I'm running b13. The HDD has only 24 Mb free and the usual temperature when running in the car is about 45?C
Is it a bug?
Cheers:
Miguel.
60Gb blue MKIIa +PCATS tuner on a Seat León 20vt FR
#118497 - 01/10/2002 08:09 Re: My Rio hangs when using Pioneer remote [Re: mpelaz]
Probably a bug somewhere.
You[b/] will have to diagnose it, using the "Button Codes Display" to see exactly what your remote is doing when you press the offending buttons/sequence.
