#124445 - 03/11/2002 09:24 Hey, Genixia, bass/treble idea...
If you can't steal any extra bits for the bass/treble controls, how about this? Have a config.ini setting:
[Hijack]
BassTrebleMultiplier=2
Then, each click of the knob (and therefore each bit increment in flash) becomes +2 or -2 instead of +1 or -1. You get less resolution (can set bass to -2 or -4 but not to -1 or -3), but a greater range (can go up to -12 instead of -6).
Make the config.ini option integer-only so the display doesn't get corrupted, and cap it at a sensible value so you don't exceed the "+" limit of the hardware (which I think is probably different whether you're stealing two EQ bands or using the DSP's built-in bass/treble if you ever manage to figure out how to do that).
#124446 - 03/11/2002 10:34 Re: Hey, Genixia, bass/treble idea... [Re: tfabris]
genixia
Hmmm...I'll take a look at that as a short term fix.
Mark has hinted to me that he might be less stingy with the flash if a proper DSP tone control were implemented.
#124447 - 03/11/2002 10:48 Re: Hey, Genixia, bass/treble idea... [Re: genixia]
Ah, nothing like incentive to get a programmer onto a project.
