#145273 - 23/02/2003 15:16
cut the time uploading to the MK2 in almost half?
Loc: Los Angeles, CA
a relevation just cale to me. i haven't tried to search if this was mentioned before, but for the ~year that i've been frequenting this board, it hasn't been mentioned.
if we use both the LAN port AND the USB port, similar to a dual WAN load balancing router, we can effectively upload tunes 1.75x faster (guesstimate). each acts as an independent channel. one track on eth, one on usb, keep it load balanced, and at the end, rebuild the database. to reduce back-and-forth hdd head movement, reserve each hdd for a seperate channel on dual drive systems.
what it would take is a rewrite of (j)emplode and probably the player software to accept more than one connection to use both at once, and i'm not sure if there would be any USB limitations... but if there is, the usb-ethernet emulation project would take care of it, right?
comments, ideas, or attempts to blow this pipe dream away welcome =)
#145274 - 23/02/2003 15:20
Re: cut the time uploading to the MK2 in almost half?
[Re: image]
I believe this has been discussed before, and the answer was that you're not going to get much speed benefit from doing something like that, because limitations in the player's hardware architecture make it so that you'd start to hit speed bottlenecks in getting the data to/from the IDE drives. Anyone have a link to that old thread on this topic?
#145275 - 23/02/2003 15:36
i remember that a USB2 conversion discussion where altman says that you cant saturate the bus... but usb2 will make it go faster than ethernet. but it leads me to believe that the bus can handle at least 2x the speed its going right now.
#145276 - 23/02/2003 16:16
[Re: image]
As Tony says, this has come up before at least once. The answer is almost certainly that neither Ethernet, nor USB, nor IDE in an Empeg has DMA hardware, and that the current best-case transfer of about 700Kbytes/sec is thus CPU-bound from all that PIO. However, I don't remember writing anything in the car-player that disables USB when Ethernet is active, or vice versa, so the Jemplode folks could possibly try it out without any player changes if they really, really wanted to. There could be other reasons it won't work, though.
#145277 - 23/02/2003 17:57
[Re: peter]
USB generates an interrupt every 64 bytes (ie, one packet). USB could *probably* be bumped up to getting almost 1Mbyte/sec with a different protocol and a FIQ interrupt handler - but at the moment, USB is speed limited by the number of interrupts that have to be processed, and the interrupt load when disk transfers are going on.
Maybe I need to talk to Patrick about a USB2 mainboard swap for the empeg... we could do a new board with the latest DSP, an Xscale, 100mbit ethernet and USB2
#145278 - 23/02/2003 18:12
[Re: altman]
Screw it, why don't you guys just release empeg Mk3 kits at that point!
#145279 - 23/02/2003 19:23
[Re: altman]
Hmm,
That almost smells/sounds like a repackaging of the Pearl mainboard given all those features....
#145280 - 23/02/2003 19:40
[Re: altman]
Loc: Manassas VA
... while your at it why don't ya throw in a color lcd and built in gps?
Brett
60Gb MK2a with Led's
#145281 - 23/02/2003 20:31
[Re: altman]
Oh, talk about a major tease. Everytime I think about what could make the empeg better, it usually boils down to "but a mainboard swap could be so much easier".
If that was even a semi-serious thought, I'd like to put in some requests now
More memory.
Removable flash drive capability for userland apps- SDcard or similar.
USB2 *host* capability.
Buffered external display capability.
Bluetooth (Hey someone else asked...)
#145282 - 23/02/2003 20:43
[Re: genixia]
Removable flash drive capability for userland apps- SDcard or similar. But if you've got USB host, you can attach your own flash reader...
#145283 - 23/02/2003 21:09
I suppose that's true...
#145285 - 23/02/2003 22:37
[Re: rtundo]
How long would a kit like that take to solder up anyway
How good are you at soldering 256 pin micro-BGA (Ball Grid Array) packages?
#145286 - 24/02/2003 04:33
[Re: genixia]
Loc: Berghem, the Netherlands
Only more reasons to release the Empeg MK3! :-)
* more memory
* 100Mbit ethernet
* USB2 host
* External display
* color LCD display
* Wi/Fi and/or bluetooth
* build in tuner
* Build in S/PDIF
* build in DVD player
* lit buttons/knob
and on and on and on....
Greetings, Robert
I am woman, here me roar! *meow*
Bubbles
#145287 - 24/02/2003 05:13
[Re: Centrknol]
Your describing Camelot (more or less)
#145288 - 24/02/2003 07:48
[Re: CrackersMcCheese]
Got a link or something?
I've done a little bit of searching but can't find anything....
Greetings, Robert
Bubbles
#145289 - 24/02/2003 08:13
Loc: Manassas VA
I'm hoping it's not double din and could be fitted in the exsisting housing for mk2...
Brett
#145290 - 24/02/2003 08:24
[Re: Centrknol]
Loc: Manassas VA
Did a bit of searching eh? Did you try the keyword "Camelot"??
This was one of the first things I came up with...
Brett
#145291 - 24/02/2003 08:37
[Re: Centrknol]
#145292 - 24/02/2003 08:38
[Re: lopan]
Damn! You beat me to it!
#145293 - 24/02/2003 11:00
Your describing Camelot.
It's only a model...
#145294 - 24/02/2003 11:20
[Re: matthew_k]
Loc: Manassas VA
And at least 4 years away...
Brett
#145295 - 24/02/2003 13:14
Loc: DFW Area, Texas, US
And if you have USB Host you cannot attach to a PC
What you want is a USB OTG port (and yes it can run at high speed)
Mark.
[blue]MKI, MKII & MKIIa, all Blue, and all Mine![/blue]
#145296 - 24/02/2003 13:26
[Re: matthew_k]
Loc: Hartsville, South Carolina for...
ROFL ![](/images/icons/smile.gif) Good call, Patsy.
Michael West
#145297 - 24/02/2003 13:28
[Re: revlmwest]
ROFL Good call, Patsy. At the San Fran dinner with Rob and Toby recently, it was explained that the "It's only a model" line was, in fact, why the product was code named Camelot.
#145298 - 24/02/2003 15:14
[Re: lopan]
Euh... only did some searching on google thinking it was an product in mass volume production....
Greetings, Robert
Bubbles
#145299 - 24/02/2003 15:29
[Re: Centrknol]
Loc: Manassas VA
![](/images/icons/wink.gif) just giving you a hard time....
Brett
#145300 - 24/02/2003 20:49
[Re: lopan]
Come on guys, Hugo's throwing us a bone and you guys are asking for the moon! How about asking about some features that would keep us under the $2000 dollar mark and not require a whole new software build.
Improved DSP w. Bass and Treble
SubOut
Digital Audio Out
100base Ethernet
USB2.0
Higher res or larger size display?
I'm just guessing here...., but what would be some features that would really help the product without adding capabiliies that only 2% of the user base would use or that would shoot the costs up so high it would never get made.
#145301 - 24/02/2003 21:02
[Re: SE_Sport_Driver]
Improved DSP w. Bass and Treble Um, the current DSP has bass and treble, it's just that no one's implemented it in the software yet.
#145302 - 24/02/2003 21:03
Bass and Treble could be implemented on the exising DSP. But I would like to see a true multichannel DSP so we could set independant delays on all speakers.
