#176014 - 20/08/2003 09:34 Negative spike bug?
MisterBeefhead
Loc: Crete, Il USA
I've recently installed my Empeg in a new (to me) vehicle, and it seems to be exhibiting some of the symptoms of the negative spike bug (forgetting song position, going straight into full off). This has me confused, as my player is a Mark 2a. Is it a known thing for the Mark 2a to exhibit the bug even though the diode that is supposed to solve the problem is already installed internally? Anything I can do about this?
_____________________________ It's getting to be ri-god-damn-diculous.
#176015 - 20/08/2003 10:09 Re: Negative spike bug? [Re: MisterBeefhead]
It also could be a wiring problem, such as a blown fuse, or the power and ignition wires being connected wrong. Check that, too.
#176016 - 20/08/2003 18:29 Re: Negative spike bug? [Re: tfabris]
MisterBeefhead
Loc: Crete, Il USA
I forgot to mention that the problem is intermittent - maybe once every three or four times I shut the vehicle off for either problem. Could it still be the things you mentioned?
I won't have a chance to take apart the dash until this weekend, but thanks for the advice, I'll update on what I find.
