#176447 - 22/08/2003 11:54 Emplode v2.0 Crashes after 2nd Hard Drive install
ernestp
Loc: San Diego,Ca USA
I'm upgrading a freind's Empeg player (MII) and have some problems with Emplode crashing at the "CheckPlayerDatabase" point in the error log.
I just install a 2nd 32 gig travelstar along with the orginal 20gig travelstar drive and ran the upgrade to format the drive and put on the 2.0 developer image (ver 2.0) so far so good. After I rebooted the unit and ran emplde for the fist time the program goes thru it normal routine and when it get's to rebuilding the database it crashes.
I enclosed a snippet of the log file for the experts to help me.
Log starts Here:
11:22:44.055 packets.cpp(1040) : I [00d0] Got 15 bytes from connection->Receive
11:22:44.055 packets.cpp(1155) : I [00d0] Got a PSOH
11:22:44.055 packets.cpp(1199) : I [00d0] Got packet length: 4 bytes.
11:22:44.055 packets.cpp(1219) : I [00d0] We've read all the data we were expecting, reading CRC.
11:22:44.055 packets.cpp(1242) : I [00d0] CRC is good.
11:22:44.055 packets.cpp(1105) : I [00d0] We got a valid packet!
11:22:44.055 packets.cpp(1112) : I [00d0] End of packet, pushing back 0 bytes
11:22:44.055 packets.cpp(1130) : I [00d0] Request::Receive(D) = 0x0
11:22:44.055 packets.cpp(897) : I [00d0] Receive result was 0x0
11:22:44.055 packets.cpp(941) : I [00d0] Got a response to packet 808080f7
11:22:44.055 packets.cpp(967) : I [00d0] Got a real reply.
11:22:44.055 packets.cpp(971) : I [00d0] Packet::WaitForReply(G) = 0x0
11:22:44.055 packets.cpp(258) : I [00d0] Request::Ping(D) = OK
11:22:44.055 protocolclient.cpp(1041) : I [00d0] ProtocolClient::WaitForUnitConnected()=0
11:22:44.055 protocolclient.cpp(1366) : I [00d0] ProtocolClient::InternalRestart()=0
11:22:44.055 database_fetcher.cpp(159) : E [00d0] CheckPlayerDatabase failed, status = 0xc0041002
11:22:44.055 DatabaseOperation.cpp(109) : I [00d0] DatabaseOperation::CloseConnection
11:22:44.055 connection_win32.cpp(451) : I [00d0] UsbConnection(00B65050)::Close()
11:22:44.055 connection_win32.cpp(465) : I [00d0] UsbConnection(00B65050)::Close()
11:22:44.055 powermgmt.cpp(40) : I [00d0] Enabling power management
11:22:44.180 FolderTab.cpp(380) : I [0910] CFolderTab::OnDownloadedNodeStore
11:22:44.180 FolderTab.cpp(250) : I [0910] CFolderTab::OnSelChangedTreeCtrl
11:22:44.180 FolderTab.cpp(141) : D [0910] CFolderTab::OnChangedFolderPath(m_folderPath = 'player/')
11:22:44.180 FolderTab.cpp(156) : D [0910] Trying to match 'player' against 'player'
11:22:44.180 FolderTab.cpp(289) : D [0910] Playlist path = 'player/'
Blk Infiniti I-30, 1 OVR 0 MkII Serial # 080000457, 120gigs +2000 Music Cd's [Listing avail]
#176448 - 22/08/2003 12:02 Re: Emplode v2.0 Crashes after 2nd Hard Drive install [Re: ernestp]
Did you follow the instructions and format the drive while it was plugged in as the primary drive? Did you apply the 2.0 upgrade onto the new drive when it was still the primary drive?
After that, did you make sure to upgrade the old drive to contain the same version (2.0 final) after you swapped it back onto the primary controller?
If all of the above conditions have been met, please see if this fixes the problem.
#176449 - 22/08/2003 14:19 Re: Emplode v2.0 Crashes after 2nd Hard Drive install [Re: tfabris]
Greetings!
Another thing to check for. You said you ran the builder. Can you post a copy of the boot log, and check for this?
#176450 - 22/08/2003 14:27 Re: Emplode v2.0 Crashes after 2nd Hard Drive install [Re: pgrzelak]
Wow, Paul has got a really good point!
Try running the builder again on the drive(s).
