Page 2 of 2 < 1 2
#182026 - 15/03/2005 14:52 Re: Hijack @dock macro? [Re: mlord]
I'd forgotten - I kept trying to get this to work, but no matter what I did with the loopback I couldn't get it to recognise it was in a dock. Which is a pity, because the workaround is to have servers forced on always...which includes when the empeg is in the car...wasting valuable resource.
Can someone reiterate which pins should be connected, and where just so I can try and get this sorted, please.
(apologies for being more moronic than usual today)
#182027 - 15/03/2005 15:14 Re: Hijack @dock macro? [Re: frog51]
#182028 - 15/03/2005 15:53 Re: Hijack @dock macro? [Re: frog51]
Because it's important to me to be able to do a cold power upgrade from within the dock, I actually did the power plug mod on the dock I purchased from Mark.
So that way, every time I plug the player into the dock, it knows it's on AC power by default and I don't have to depend on the dock loopback connector.
#182029 - 15/03/2005 17:49 Re: Hijack @dock macro? [Re: tman]
Okay, that helps a bit - mine is built from a car sled, so I'll need to check my pins 6 and 7 to see I have things the right way round.
I might just follow Tony's idea and go for the power plug mod.
#182030 - 23/04/2005 11:31 Re: Hijack @dock macro? [Re: wfaulk]
ukengb
Loc: United Kingdom
So does Hijack still/now include the ;@DOCKED option?
#182031 - 23/04/2005 15:46 Re: Hijack @dock macro? [Re: ukengb]
I'm sure it does, but that doesn't help flash upgrades. The part of protected flash that waits on the serial port for an upgrade signal is executed before the kernel takes over. So if you are sled-docked and the AC sensor switch isn't tripped, there is no way for the player to listen for a serial port upgrade. No matter what tricks hijack does.
Page 2 of 2 < 1 2
