#183722 - 08/10/2003 17:17 Definately Need a case for this thing
booey
The front seems like it scratches really easy. Definately need some kind of case for this thing, besides the little pouch it came with. Something that still keeps its small shape, with clear plastic protecting the front or something like that..
b
#183723 - 08/10/2003 17:35 Re: Definately Need a case for this thing [Re: booey]
I would like a belt clip.
#183724 - 08/10/2003 17:53 Re: Definately Need a case for this thing [Re: msaeger]
Hmmm... The final production units were supposed to have a clear coat protection to prevent (or at least help to prevent) scratches. I hope that was not left out!
Meanwhile, the beta team has been begging for a belt clip or case with a belt loop since the beginning.
#183725 - 08/10/2003 18:09 Re: Definately Need a case for this thing [Re: pgrzelak]
It looks like there is a coating the front is shiny. I would like a clip like motorola blackberry has where you leave the clip / holster on your belt and unclip the karma from it.
#183726 - 08/10/2003 20:20 Re: Definately Need a case for this thing [Re: pgrzelak]
elinenbe
Loc: New York, NY
As far as I know it does not have the clear cover. I have placed it dace down on a smooth wood table, and it already seems pretty scratched up (light scratches though). I would suggest keeping it in its case because the front is really shiny and the shiny part is large. The ipod is very similar and that is why everyone and their mother makes cases for it.
#183727 - 08/10/2003 20:36 Re: Definately Need a case for this thing [Re: elinenbe]
booey
i have carried this thing like its a glass filled to the rim with chemical nerve agent, and cradled it like a newborn baby since i got it, and i still see some scratches on it, so i dont think there is any protective coating on it.
b
#183728 - 19/10/2003 02:14 Re: Definately Need a case for this thing [Re: elinenbe]
JaBZ
Loc: NZ
I would suggest keeping it in its case..
so it comes with a case?, or cloth bag?
Jai
#183729 - 19/10/2003 02:19 Re: Definately Need a case for this thing [Re: JaBZ]
Bag
#183730 - 10/03/2004 10:24 Re: Definately Need a case for this thing [Re: msaeger]
Has anybody found a case/screen protector? I've had mine less than a week and it's already well scratched
#183731 - 10/03/2004 14:27 Re: Definately Need a case for this thing [Re: tahir]
brendanhoar
I'm looking for an armband carrier. I checked the riovolution.com recommendations and they were almost all out of stock and/or discontinued. Recommendations?
I'd prefer something with a covered, but clear, face.
#183732 - 10/03/2004 16:10 Re: Definitely Need a case for this thing [Re: tahir]
Mach
Loc: Texas, USA
As to scratches, I would recommend either laminating the front screen with clear plastic or getting a cling film PDA screen protector and trimming it to size. Get a sheet of laminate (a4 or 8.5 x 11), cut a piece 0.5" bigger than your Karma, place it over the Karma to get an idea of where the stick is going to come through by laying on top a coin of approximately the same size as the stick divot. Carefully remove the Karma from underneath the laminate without moving the position of the coin. (You can tape the coin down if you prefer) Use a sharp X-acto knife to trim around the coin. You should be left with a squarish piece of laminate with a coin size hole in it. Clean the face of your Karma and make sure it's dry. Now, peel the laminate paper off on the hole corner only and carefully position it so it lines up with divot and the rest of the Karma corners. Be careful not to touch the laminate on the sticky side as you will be looking at finger prints for a long time. Once its positioned on that corner, slowly peel the laminate paper off while smoothing it down starting from the corner and working outward. If you try to do the whole thing at once, you'll get bubbles so take it slow. Once the laminate is down and smooth, use your (very sharp) Xacto knife to slowly and carefully trim around the menu button and the outer edge of the screen. Take it very slow on this part keeping the tip of the Xacto in the crack between the plastics. Do not attempt to cut directly on top of the screen or cutout the hole for the divot while its on the player. You will scratch the screen (ask me how I know).
As for cases, I picked this one up on a trip through Heathrow. It fits the Karma well but not too snugly with room to spare for headphones. (I superimposed a picture of a karma on the case...see photo). It has a strap on the back for placing it on a belt. It comes with a neck strap also.
http://www.essentials4travel.com/mall/productpage.cfm/e4t/dsg0013/33407/Design%20GO%20all%20in%20carrying%20case
I also see that Design GO also makes a hard sided case but I haven't tried it with my Karma.
http://www.essentials4travel.com/mall/productpage.cfm/e4t/dsg0014/25595/Design%2DGO%20e%2DSafe%20carrying%20case
Edited by Mach (10/03/2004 16:13)
#183733 - 11/03/2004 04:46 Re: Definitely Need a case for this thing [Re: Mach]
I'll get some PDA screen protector
