#186029 - 22/10/2003 09:55 Kill autoplay
thinfourth2
Okay how do i kill this wonderful autoplay feature on a win2k machine
sugestions involving violence will be considered !
#186030 - 22/10/2003 09:57 Re: Kill autoplay [Re: thinfourth2]
RobotCaleb
well, without looking myself you can try holding the shift key on insertion.
but since im on a win2k machine, ill look.
#186031 - 22/10/2003 10:01 Re: Kill autoplay [Re: thinfourth2]
RobotCaleb
Turn Off CD Auto Play Win2000 the Microsoft way
Click Start, click Run, type regedit in the Open box, and then press ENTER.
Locate and click the following registry key:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom
To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1.
Restart your computer.
NOTE: This method disables automatically running CD-ROMs. If you want to disable automatically running CD-ROMs depending on the CD that you insert in the CD-ROM drive, you can press and hold down one of the SHIFT key while you insert the CD.
Additional Information
There are two other registry keys that can affect this functionality:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
NoDriveTypeAutoRun = 0x00000095
-and-
HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
The correct value for each is 0x00000095.
from here
#186032 - 22/10/2003 10:03 Re: Kill autoplay [Re: RobotCaleb]
ashmoore
Loc: TX
recommending that you press the shift key to disable autoplay is a risky business nowadays.
========================== the chewtoy for the dog of Life
#186033 - 22/10/2003 10:04 Re: Kill autoplay [Re: ashmoore]
RobotCaleb
heh
true
#186034 - 22/10/2003 15:51 Re: Kill autoplay [Re: RobotCaleb]
You can do it with tweakUI too.
#186035 - 23/10/2003 12:19 Re: Kill autoplay [Re: msaeger]
lectric
Loc: New Orleans, LA
Matt, you still use Be?
#186036 - 23/10/2003 20:28 Re: Kill autoplay [Re: lectric]
No I haven't used it for a while but I found the box while digging through a closet and thought it would make a good icon.
#186037 - 24/10/2003 12:23 Re: Kill autoplay [Re: msaeger]
lectric
Gotcha. A good friend of mine (two good friends, actually) wrote BeCommander. Was just curious if you ever used it.
