#19329 - 02/10/2000 21:48 connecting to line in on sony head unit
hello
does anyone know the part number or where I can get the device that will allow me to connect the empeg to the line in on a sony head unit
I have seen the device now I can't find it anywhere I thought I read a post on this messave board about someone using it but a search for sony only reveals info about using the stick remote
thanks
matt
#19330 - 04/10/2000 12:31 Re: connecting to line in on sony head unit [Re: msaeger]
Cambscar
Loc: Cambridge, UK
The part you're after is the XA-107(assuming your unit's got Unilink changer control). If you want to use it in conjunction with a CD changer, I think you'll probably also need an XA-C30 switching unit.
Info on both at http://www.ice.sony.co.uk/product/allmodels.asp?Category=Accessories&Type=Other
HTH
Dominic
Cambridge Car Audio
http://www.cambscaraudio.co.uk
#19331 - 04/10/2000 17:19 Re: connecting to line in on sony head unit [Re: Cambscar]
thank you very much I asked several car stereo shops here as well and crutchfield none of them knew about it
