Paul - first, thanks for all your hard work.
I just got my first Rio yesterday, and set aside some time tonight to play with tRio, and have it working (mostly).
I'm running XP, and still have ARM (jReceiver is the next free evening).
I've got the web applet running fine, and it'll play songs on my HD just fine. However, when trying to stream, I get the following error: (this is only the first handful of lines)
PlayerStream (/192.168.0.105) - streamStart()
Opening station content url: ST6, conn: sun.net.www.protocol.http.HttpURLConnect
ion:http://www.shoutcast.com/sbin/shoutcast-playlist.pls?rn=8167&file=filename.p
ls
Opened station content url: ST6, method: GET, header fields: {X-Powered-By=[PHP/
4.1.1], Connection=[Keep-Alive], Date=[Thu, 21 Aug 2003 05:16:10 GMT], Keep-Aliv
e=[timeout=15, max=100], Server=[Apache/1.3.26 (Unix) PHP/4.1.1], Content-Type=[
audio/x-scpls], null=[HTTP/1.1 200 OK], Transfer-Encoding=[chunked]}
got line: [playlist]
got line: numberofentries=5
got line: File1=http://64.236.34.141:80/stream/1018
http://64.236.34.141:80/stream/1018, conn: sun.net.
www.protocol.http.HttpURLConnection:http://64.236.34.141:80/stream/1018
Updating config file
Error: java.net.ConnectException: Connection timed out: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
Any clues for this newbie?
Thanks.
