Page 2 of 2 < 1 2
#230557 - 11/02/2005 07:20 Re: Mini Cooper S install? Need help b4 I buy one! [Re: msaeger]
jbauer
Loc: San Francisco, CA
I just got mine back from the installer and it's awesome. The empeg fits into the dash very well since it's all black and the factory radio is only slightly larger so there is only a little of the trim plate showing.
Hi Matt,
So what are you doing (if anything) about the MFSW controls? Are you trying to get those to work with the Empeg also?
- Jon
#230558 - 11/02/2005 10:09 Re: Mini Cooper S install? Need help b4 I buy one! [Re: jbauer]
I haven't done anything yet but I am planning on getting one of these .
I also have a swix laying around I could use too but I would rather use the wired one.
I will probably order the newministuff one in a couple of weeks (just spent 1000 on install ) it will cost about 100 dollars after exchange from pounds to dollars and shipping.
I figured it would be nice at least to have volume and track up/down
#230559 - 24/02/2005 01:28 Re: Mini Cooper S install? Need help b4 I buy one! [Re: msaeger]
busdepot
I thought about doing that but I decided there wasn't enough room after ripping the tubes out and holding the empeg under there.
I can now report that the Empeg will fit in the Mini console at the bottom, below the heater controls, without having to modify the console support tubes. It is very close but it does fit.
#230560 - 24/02/2005 01:53 Re: Mini Cooper S install? Need help b4 I buy one! [Re: busdepot]
Got a picture ?
Page 2 of 2 < 1 2
