Page 2 of 2 < 1 2
#247649 - 08/02/2005 06:41 Re: Elperepat- Current experiences with SYLT plugin [Re: tfabris]
Gonna have to go try this tonight after the kids go to bed - my tagged tracks certainly seem fine in the car, so I hope they are.....retagging 100 tracks may not be that much fun
#247650 - 08/02/2005 20:33 Re: Elperepat- Current experiences with SYLT plugin [Re: frog51]
Am I the only one who can no longer edit ID3 tags in WinAmp with that plugin?
#247651 - 09/02/2005 02:14 Re: Elperepat- Current experiences with SYLT plugin [Re: tonyc]
So, to recap, switching to that mpg123 plugin is the solution to the timing problems?
Yes.
If so, any way the plugin could detect which one is selected and complain/warn if it's not the one we want?
I suggested this very thing to Patrick in Instant Messenger mere moments after confirming that the mpg123 pluging solved my problems.
I never tried, but the readme for mpg123 says:
"*** ID3 tag editor is not fully tested. Backup your file before using this function. ***"
So I suppose that would be expected behavior.
Well, it's easy enough to switch back to the regular plugin (just put "MP3" back into the configuration screen for in_mp3.dll).
#247652 - 09/02/2005 03:08 Re: Elperepat- Current experiences with SYLT plugin [Re: tfabris]
I usually use MP3 Tag Studio anyway, but occasionally I see a problem and correct it on the fly in winamp. I'd rather have correct lyric timing though, and it's a pain to switch back and forth, so I'll just use MP3TS.
#247653 - 09/02/2005 04:02 Re: Elperepat- Current experiences with SYLT plugin [Re: JBjorgen]
matthew_k
If you're using XP, it's got a basic tag editor that's slightly better than winamp for those occasional problems... It works for me in those cases when I don't feel like fireing up mp3ts.
#247654 - 09/02/2005 04:33 Re: Elperepat- Current experiences with SYLT plugin [Re: matthew_k]
DOH! little did I realize, that's why the properties box was popping up when I tried to edit the ID3 tag. It was pulling up the WinXP tag editor.
/me goes back to hide in his hole.
#247655 - 09/02/2005 07:57 Re: Elperepat- Current experiences with SYLT plugin [Re: tfabris]
On a quick bit of checking, some of mine appear to be fine, and a couple not so good so I'll go through and retime where necessary. I was going to do a quick spelling review anyway so ... sigh
#247656 - 09/02/2005 11:37 Re: Elperepat- Current experiences with SYLT plugin [Re: JBjorgen]
Just as a reminder... Even when Winamp was using the original in_mp3.dll instead of mpg123, if you corrected the ID3v2 tag in Winamp, it will erase your SYLT lyrics from the tag.
I don't recall if MP3 Tag Studio preserves the SYLT tag by default, or if you must check a configuration option in order for it to do that. And I have no clue if using the tag editor built into Windows XP will harm the SYLT tag or not.
Happy Birthday!
#247657 - 09/02/2005 18:46 Re: Elperepat- Current experiences with SYLT plugin [Re: tfabris]
Useful information. Noted.
Happy Birthday!
Thanks!
#247658 - 11/02/2005 11:37 Re: Elperepat- Current experiences with SYLT plugin [Re: tonyc]
srhodes
Loc: Derbyshire, UK
I was happy to stick with Winamp 2.74 until .... it seemed to work alright on the first night, the timing MP3s were perfect and I tagged a file which worked fine on the empeg. Tried to tag another file a couple of nights later and got the lag problem.
I have now downloaded 5.08 lite and changed to the mpg123 plug-in. It works like a treat.
Thanks to all who came up with (and refined) the solution.
Steve
2x80GB Mk II with Illuminated buttons
Page 2 of 2 < 1 2
