Page 6 of 6 < 1 2 3 4 5 6
#306833 - 03/02/2008 21:03 Re: Will the plane fly? [Re: peter]
Heh - 90 knots is pretty normal windspeed back home. It isn't as destructive as high winds in England for a few reasons:
Trees - none. Or almost none. We have some 40 year old oaks that are 7 feet tall, as that is the height of the wall.
Gusts - none. The wind just blows. From west to east.
Buildings - blimming solid construction!
They are good aircraft - I used to get to fly one round the mountains in the Falklands. And they can land on anything - beaches, mud, grass, runways... And Dad was a bit of a mental pilot (was fleet air arm - Buccaneer pilot!) so would go for any manoevre that seemed fun. He managed a few vertical takeoffs too!
Back on topic - when I used to fly r/c gliders I used to lie on a steep west facing slope and hold a glider at arm's length. A decent 2.5m wingspan glider would happily climb from my hand with a windspeed of anything over about 30 knots (well, less than that at 1m off the ground I suppose.) Landing back into the hand was much trickier - only really simple with a glider with airbrakes/spoilers.
#306842 - 04/02/2008 07:25 Re: Will the plane fly? [Re: frog51]
julf
Cool! When were you down there?
#306847 - 04/02/2008 09:04 Re: Will the plane fly? [Re: julf]
Between '82 and '87 I was there a fair bit, and I went back a few times until around '91. Dad set up the Falkland Islands Government Air Service, which up until then consisted of two Beaver floatplanes, and as he was then Loganair's chief pilot and had a fair bit of time in that sort of environment he organised the airfields and procedures etc. It's an amazing place. I keep trying to work out cost effective ways to take SWMBO there on holiday.
Have you managed to visit the islands?
#306854 - 04/02/2008 12:33 Re: Will the plane fly? [Re: lectric]
Originally Posted By: lectric
I have an extremely intelligent friend that simply cannot wrap his head around this problem. He is just having a hard time separating airspeed from ground speed. For some reason he's having a mental block about the air above the belt not moving WITH the belt.
Instead of a conveyor belt, explain it as taking off on a sheet of ice. It is the same principle as the conveyor belt without all the extra red herrings of friction, belt speed, etc thrown in.
#306867 - 04/02/2008 15:36 Re: Will the plane fly? [Re: Tim]
Oh! I like that twist!
Then you can ask the question "How long is the landing rollout on ice?"
Answer: the same length as if you didn't touch the brakes on a normal landing. lol
#306879 - 04/02/2008 18:43 Re: Will the plane fly? [Re: frog51]
julf
Not yet, but some of my friends have. And I have some interesting "artifacts" from the war. The most interesting is a circular circuit board, designed to fit inside a sewer pipe. It has a radio receiver/detector that detects a combination of 2 audio carrier tunes, and after receiving that special carrier (from, let's say, an airplane with a suitable transmitter that flies past, it counts down for one week (suitable time period to make everything untraceable / deniable) and then issues a detonation signal...
Seems teh argentinians left a bunch of them in sewer pipes, along with a fair bit of TNT...
#306883 - 04/02/2008 19:31 Re: Will the plane fly? [Re: julf]
Speaking of airplanes and Argentina...
Want
/slobber drool
#306898 - 05/02/2008 02:12 Re: Will the plane fly? [Re: Robotic]
Just found this video clip of a sea plane taking off from a trailer behind a truck.
Who needs a conveyor belt?
edit:
and another of a nifty glider takeoff.
Edited by Robotic (05/02/2008 02:19)
#306902 - 05/02/2008 06:58 Re: Will the plane fly? [Re: julf]
Yes - we ended up with a few souvenirs after they had been defused. The most interesting were some mines, a bazooka and two rifles, but the only ones we got back to UK were the mines. Luckily we didn't find anything booby trapped!
#306903 - 05/02/2008 07:45 Re: Will the plane fly? [Re: frog51]
julf
Do you need a deactivation certificate for the mine?
#306919 - 05/02/2008 17:47 Re: Will the plane fly? [Re: julf]
oh yes:-) They were very strict on that, for my antipersonnel and my antitank mine.
#306945 - 06/02/2008 07:22 Re: Will the plane fly? [Re: frog51]
julf
picky, picky... smile
