Page 1 of 3 1 2 3 >
#277239 - 10/03/2006 15:27 No hard disk found
The streak has ended. After over five years without a problem, I loaded the empeg into my car today and there was Tux with a friendly message of "No hard disk found. Contact support."
*sigh*
It's been a little frustrating for me lately in regards to my car stereo. First the left channel kept crapping out on me, and somehow Rob fixed that. Then recently I went a couple weeks without being able to turn the volume up past -32dB or else it would get all distorted. My installer took a look at it, found the fuse in the system was faulty, replaced that and I had a whole day of no-problem music listening. Then this.
Please help! I've never so much as opened my empeg up, and the thought of it scares me. This is my only child and I don't want to lose it! Does it sound like the hard drive cable has come loose? Did the hard disk simply fail? Is it something else? I'm going to try to open it up, but I can't seem to find a proper size hex tool around here. I'll keep looking.
I had taken it out of the car this morning to load some new CDs on it. When I went to synchronize, it was taking a really long time on the "checking disk integrity" part, so I left it to go get breakfast. I came back about an hour later and the player was turned off and emplode was just sitting there, so I assumed it has completed successfully.
Damn.
Thanks for any help you guys can give me.
#277240 - 10/03/2006 15:31 Re: No hard disk found [Re: Dignan]
It might be that the connector came loose, given that it was repaired recently and probably bounced around a bit in transit. Also, it sounds like your disk symptoms were rather sudden and absolute - usually cable crimp or header problems are slow and build over time.
#277241 - 10/03/2006 15:36 Re: No hard disk found [Re: pgrzelak]
No, the empeg wasn't sent anywhere. The last time it was sent away for repairs was some time over five years ago. I suppose the folks at the car audio place could have done something to it, but probably not.
Rob R fixed the left channel problem I was having when he came down here a couple months ago. And that was more with the wiring of the sled, I think.
#277242 - 10/03/2006 16:08 Re: No hard disk found [Re: pgrzelak]
The disk connector is severely stressed each time an empeg is simply carried by the handle..
#277243 - 10/03/2006 18:42 Re: No hard disk found [Re: Dignan]
schofiel
Well, you know the drill by now, serial log blah blah take off lid blah blah tell us what colour stripe the cable has blah-di-blah etc. etc.
#277244 - 11/03/2006 10:51 Re: No hard disk found [Re: schofiel]
Schido
I recently saw the dreaded 'no hard disk found' message too.
I was so relieved when i opened the player, and spotted the ide cable connector loose from the harddrive.
Taped back into place now.
#277245 - 11/03/2006 22:42 Re: No hard disk found [Re: schofiel]
oliver
Sorry to hijack this thread, but my buddies empeg is doing the exact same thing. It didn't help when his stereo rack fell over and the empeg got crushed by a 40 pound hafler pro 2400 amp. Anyways, his IDE cable has a black strip and smaller connectors. Nothing seemed to be loose, I can still hear the hard drive spin up, and I can't see any broken headers (I've spotted them before). I tried putting another 20gb hdd from my spare empeg into his unit, and it doesn't even boot correctly. It gets stuck on the empeg screen and the tux doesn't walk into the picture. Should I just run the builder on my spare 20gb to see if he broke the hdd or his empeg?
277659-CAPTURE.TXT (178 downloads)
#277246 - 12/03/2006 00:00 Re: No hard disk found [Re: oliver]
This merely means he's got the 1.0x firmware and never upgraded to 2.0.
This is the exact same thing as getting "no hard disk found contact support" and you need to go through all the same diagnostic steps listed in the FAQ under "no hard disk found contact support"
#277247 - 12/03/2006 03:07 Re: No hard disk found [Re: tfabris]
oliver
gotcha, thanks tony!
#277248 - 12/03/2006 16:38 Re: No hard disk found [Re: schofiel]
˙If there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v410 ([email protected]) (gcc version
2.95.3 20010315 (release)) #2 Wed Aug 4 00:27:49 EDT 2004
Checking for extra DRAM:
c0c00000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 7, serial number 80000408) 12MB DRAM
Command line: mem=12m
Memory: 10952k/12M available (984k code, 20k reserved, 328k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9937c
Tuner: loopback=0, ID=-1
Scheduling custom logo
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005800).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:9
8
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...el panic: VFS: Unable to mount root fs on 03:05
Done.
It looks like a black stripe to me.
At the very least, this has prompted me to finally buy another hard drive. I just picked up an 80GB drive. Can't wait to load all my music on there I just have to get this working now...
Edited by Dignan (13/03/2006 03:19)
#277249 - 13/03/2006 03:29 Re: No hard disk found [Re: schofiel]
Well, it turned out to be pretty simple. I opened the player up and lifted out the drive tray. I then saw that the cable was half off the main board. I pushed that into place, plugged in the player and it started up right where my playlist left off.
However, this opportunity seemed like a good one to have a go at upgrading my capacity. So I followed the instructions in the FAQ, which were a bit scary for someone who's never seen the inside of his own empeg, but I soldiered through.
Once finished, I booted up with hyperterminal running and it indicated it could see the two drives. I then launched emplode to check my new capacity, and was disappointed to see it still at 11GB.
I'm pretty sure I know the problem, though, so I'm not too worried. The drive I bought was a Western Digital (it was the only brand I recognized in the store), but the only problem is it didn't come with a jumper. I gave it a go to see if it would work without one. I guess it didn't. Does it sound like if I just get a jumper, the problem will be fixed? And if so, my next problem is that I can't find any documentation telling me what the jumper settings are (and no, it's not written on the drive). Anyway, here's what hyperterminal has to say:
Probing primary interface...ress.cpp189 (14
hda: IBM-DARA-212000, ATA DISK drive
hda: IBM-DARA-212000, ATA DISK drive: Spinning up.est complete:
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
8
Partition check:
Press Ctrl-A to enter pump...hange_root: old root has d_count=1
Freeing unused kernel memory: 4k init player.cpp : 385:empeg-car 2.00-be
ta13 2002/07/24.
Vcb: 0x4054d000
#277250 - 13/03/2006 09:40 Re: No hard disk found [Re: Dignan]
Well as you can see, there's no mention of the Western Digital anywhere.
Currently, you'll have the IBM as the primary and the WD should be the slave. It might or might not need a jumper to make a slave - depends on the manufacturer. You could try just a boot without the IBM (doesn't matter which connector) and you should see just the WD drive instead.
The drive should have diagram on it for the jumper settings before you go rushing to the store to get one.
Personally I'd set the new WD to be the primary (since it's the newer and hopefully more reliable) and the old IBM as a slave after building both drives with the builder image. That way if either drive dies, your empeg should still somewhat work although you might have to disconnect the dead drive.
#277251 - 13/03/2006 10:56 Re: No hard disk found [Re: Shonky]
I'm not too hot on loosing all the music that's already on there. I'll think about it though.
And I eventually found a PDF that shows how the jumpers are set.
Does anyone know a physical store that sells jumpers in the DC area?
#277252 - 13/03/2006 11:19 Re: No hard disk found [Re: Dignan]
Why would you lose anything?
I'm not suggesting removing the old IBM. Just make it the secondary drive. For most intents and purposes it won't make any difference really. The WD drive will fill up first (assuming it's bigger) until the drives have equal space left. Then the software will alternate between drives until they are full.
And then if you wanted to go to 1 drive, assuming the WD has enough space, you can move all the files from the old drive to the new drive while on the empeg. Not super fast, but not super slow either.
#277253 - 13/03/2006 11:58 Re: No hard disk found [Re: Dignan]
Check that the new drive is jumpered as "slave" (you MUST manually do this, as the factory default is never "slave").
Also, go into the Hijack menu, to the Hard Disk Detection setting, and ensure it is set for One or Two Drives.
#277254 - 13/03/2006 12:32 Re: No hard disk found [Re: Shonky]
Doesn't applying the builder image completely wipe the hard disks?
Thanks, Mark. I suspected I'd need a jumper. The PDF I found proves that the WD with no jumper is the default for master or single. Now I just have to find a store around here that sells 2mm jumpers (I want this fixed ASAP ). I'm pretty sure I saw that Microcenter had them, but I'm not certain...
#277255 - 13/03/2006 12:37 Re: No hard disk found [Re: Dignan]
PM me your address and I'll drop a couple in an envelope and send 'em your way. I had to buy a minimum of 10 or so when I bought mine.
#277256 - 13/03/2006 15:04 Re: No hard disk found [Re: Dignan]
Yeah, which is why you leave the old disk unplugged while the builder does your new one. Then you can use the new disk as the master, and the old one as the slave.
The player doesn't care, as long as the player software is loaded onto the master.
#277257 - 13/03/2006 15:47 Re: No hard disk found [Re: Roger]
I understood that much, but I've been reading things very specifically in this process, and I was mainly focusing on the part where he said "building both drives with the builder image." That would lose all the data, I said so, and he then said I wouldn't. I just wanted to be crystal clear on it
I did format the new drive in that way, so when I get the jumpers I may arrange them just like you said. That sounds fine.
#277258 - 13/03/2006 17:06 Re: No hard disk found [Re: Dignan]
I'm in South Carolina, so I'd imagine you'll get them tomorrow or Wednesday at the latest.
#277259 - 13/03/2006 18:06 Re: No hard disk found [Re: JBjorgen]
Thanks again. I'll let you know if it works.
#277260 - 13/03/2006 19:34 Re: No hard disk found [Re: Dignan]
Sorry poor choice of words. The IBM is already "built". There is no need to rebuild it. In the end both will be built so either will work if the other dies.
#277261 - 14/03/2006 01:40 Re: No hard disk found [Re: Shonky]
Sorry, I've just been a little frazzled by this whole process. It's a little nerve wracking to do on my only empeg.
So I tried removing the IBM disk from the cable and plugging in the WD drive. When I tried opening emplode, I had problems. It saw the empeg, and it started going through the process. When it got to the "checking media" part, I got a Windows error and emplode crashed. So I fired up hyperterminal and this is what I saw:
Probing primary interface...Poll result=0 on fd=514): Po
hda: WDC WD800VE-07HDT0, ATA DISK drive14
Stressing /dev/hd
hda: WDC WD800VE-07HDT0, 76319MB w/8192kB Cache, CHS=9729/255/63
8
Partition check:
Press Ctrl-A to enter pump...change_root: old root has d_count=1
okay
Freeing unused kernel memory: 4k initVFS: Can't find an ext2 filesystem on dev i
de0(3,4).
! tags.cpp : 61:Failed to open tags (0xc0041002).
Vcb: 0x4054d000
What does it all mean?
#277262 - 14/03/2006 01:57 Re: No hard disk found [Re: Dignan]
Your HyperTerminal set up is munging the logs a bit, so things are a little hard to interpret.
The WD drive is showing up as a primary which is good.
The "Stressing /dev/hd" tends to imply that you still have the builder image on that drive. However it then appears the player software runs. Perhaps HyperTerminal is remembering an old session?
Are you sure you applied the builder image to the new drive AND then applied the developer image?
#277263 - 14/03/2006 04:27 Re: No hard disk found [Re: Shonky]
I was absolutely certain. 100%
I was wrong. I had the consumer image. Crud.
I'm loading the developer image now. I never did like the way the download page is layed out...
#277264 - 14/03/2006 04:30 Re: No hard disk found [Re: Dignan]
Again a bad choice of words...
You don't need the developer image, but there's not a lot of point in not having it. However you must apply either the consumer or the developer image after the builder image has built the drive to actually use the empeg.
Your log showed a message that only appears in the builder image. That's why I'm confused.
#277265 - 14/03/2006 04:40 Re: No hard disk found [Re: Shonky]
I'm not sure how good that log is. I think I may have copied some past information in there. I can't read the thing, so if it scrolls past a page, I don't know where that session began.
So I installed the developer image anyway. You're right, it doesn't make a difference. When I select the player in emplode, it gets to the "Checking media" portion and says it's checking the integrity, at which point the player restarts and then emplode crashes. I'm giving up for tonight. I have to get some sleep...
Thanks for the help, though.
#277266 - 14/03/2006 04:54 Re: No hard disk found [Re: Dignan]
Hmmm. I'm not real sure then. I'd probably try doing a manual fsck like this if it's crashing or something while "checking media". Without the second drive you don't need to do the lines with hdc in them.
The manual fsck (which requires the developer image you now have ) might provide some clues as to what's happening since you'll be able to see any errors generated.
Edit: I'm basing this purely on the fact that I assume "Checking Media" is doing a fsck. Perhaps it's something like the swap partition isn't working properly.
Edited by Shonky (14/03/2006 04:57)
#277267 - 14/03/2006 08:04 Re: No hard disk found [Re: Dignan]
The Copy/Paste functionality in Hyperterminal is severely screwed up. Either use the File / Capture Log menu item (I think that's what it's called) to save the log to a file, or use a different serial terminal program (like TeraTerm).
#277268 - 14/03/2006 11:57 Re: No hard disk found [Re: Roger]
I'll try that when I get home tonight. I don't suppose the attached emplode log is of any help...
(it's just the end of the log, since the whole log was too big to attach)
277905-emplode.txt (193 downloads)
Page 1 of 3 1 2 3 >
