Page 2 of 2 < 1 2
#288971 - 03/11/2006 15:19 Re: JEmplode "ethernet broadcast" discovery protocol bug? [Re: mlord]
Ahh.. bingo. Something is causing it to parse /etc/hosts to try and find the local ip address. Why does it do such a silly thing? Dunno, but it does.
Again, because Java doesn't have hooks low enough in the IP stack to get it to return quality IP addressing information.
#288972 - 03/11/2006 15:22 Re: JEmplode "ethernet broadcast" discovery protocol bug? [Re: mlord]
Ahh.. waitaminute.. there was a loopback entry in /etc/hosts for the local hostname.. delete that line completely and it also now works.
Speaking of which:
You probably have a decent amount of pull in the Linux community. Can you tell everybody that this default of having the local hostname in /etc/hosts as 127.0.0.1 is complete brokenness, please? I know it's not a Linux issue, but virtually every distribution does it and it's 100% wrong. It causes a lot of problems like this.
#288973 - 03/11/2006 16:04 Re: JEmplode "ethernet broadcast" discovery protocol bug? [Re: mlord]
It all makes sense now in the edited post above. The 255.255.255.255 address is the only one that is actually working here, because of my 7-bit subnet.
Except that that doesn't make sense -- because it was sending to 255.255.255.255 even before you changed /etc/hosts...?
#288974 - 03/11/2006 16:09 Re: JEmplode "ethernet broadcast" discovery protocol bug? [Re: peter]
Yeah, but then I'll bet it was using 127.* as the reply address..
#288975 - 03/11/2006 16:13 Re: JEmplode "ethernet broadcast" discovery protocol bug? [Re: mlord]
Packets with 127.0.0.1 as the src_ip? Oooh, by binding the local UDP socket to it? Is that even allowed? If so then I guess that would explain why Wireshark didn't see the packet -- if you had it set up to filter on src_ip=<the.correct.address>...
Page 2 of 2 < 1 2
