Page 3 of 3 < 1 2 3
#320700 - 26/03/2009 14:46 Re: Computer building woes.... [Re: msaeger]
burdell1
so i sent it in to intel but rejected it because of the "thermally damaged circuit board." however, when i sent it in to them, they had me put the little cover over the cpu area and in the process, i think it damaged a couple of the pins (they won't go back in.) do i dare put the CPU back on it (to try to fix the bios again)
#320701 - 26/03/2009 14:52 Re: Computer building woes.... [Re: burdell1]
No. If you've damaged the socket then your motherboard is junk. It is possible to get the socket replaced but it would be expensive and not worth it.
#320710 - 27/03/2009 00:14 Re: Computer building woes.... [Re: tman]
R.I.P.
Page 3 of 3 < 1 2 3
