#310183 - 14/05/2008 20:02 EmpegNotifier
I've just spent the day hacking together the first version of "EmpegNotifier". I think of it as AutoPlay for your empeg. It sits in the notification area (the tray) and watches for empegs coming and going on the local network (network-only at the moment, I'm afraid).
My plan is that you'll be able to attach actions to events (i.e. when your empeg appears on the network, run emplode). At the moment, however, it just watches for empegs and updates the icon and tooltip text.
If anyone fancies giving it a whirl, please let me know how you get on. Suggestions welcome. I've tested it on Windows Vista, but I think it'll work on Windows 2000 and newer.
EmpegNotifier-20080514.zip (368 downloads)
#310184 - 14/05/2008 20:45 Re: EmpegNotifier [Re: Roger]
siberia37
Loc: Tacoma,WA
Very cool- I will be installing it on my machine at home. Can't wait for an auto-load of Emplode action.
#310188 - 15/05/2008 01:11 Re: EmpegNotifier [Re: Roger]
First thing it should do: Write out a HOSTS file entry that assigns the IP address of the Empeg to "EMPEG" :-)
#310190 - 15/05/2008 03:58 Re: EmpegNotifier [Re: tfabris]
First thing it should do: when it finds an empeg, spawn a program that updates the HOSTS file...
You see where I'm coming from? wink
#310193 - 15/05/2008 09:00 Re: EmpegNotifier [Re: Roger]
What a nice idea. I'll have a play with that later on.
#310195 - 15/05/2008 12:24 Re: EmpegNotifier [Re: Roger]
StigOE
And removes the entry when the empeg leaves the network.
But what if you have more than one empeg connected to the network at the same time? Is it possible for the program to find the empeg name and use that in the HOSTS file?
Stig
#310197 - 15/05/2008 12:41 Re: EmpegNotifier [Re: StigOE]
excellent smile
Is is KDE or Gnome?
#310199 - 15/05/2008 12:48 Re: EmpegNotifier [Re: StigOE]
Yep. That's the plan.
Yes.
#310200 - 15/05/2008 12:49 Re: EmpegNotifier [Re: LittleBlueThing]
excellent smile
Is is KDE or Gnome?
Windows-only at the moment. I'll look at carving up the interesting bits of code so that someone can write a KDE/GNOME version.
#310204 - 15/05/2008 13:30 Re: EmpegNotifier [Re: Roger]
WinForms stuff works passably well under mono on Linux now, though obviously system tray functionality might be a bit of a problem.
#310206 - 15/05/2008 14:08 Re: EmpegNotifier [Re: andy]
This program's written in C++, mainly because of size constraints.
#310207 - 15/05/2008 15:12 Re: EmpegNotifier [Re: Roger]
excellent smile
Is is KDE or Gnome?
If you coded it using QT, then it should "just work" for all three.
#310211 - 15/05/2008 16:51 Re: EmpegNotifier [Re: mlord]
Qt .... mmmm.
#310214 - 15/05/2008 19:09 Re: EmpegNotifier [Re: tfabris]
AndrewT
Loc: Oxford, UK
Since when did changing the HOSTS file stop needing a reboot for the changes take effect? blush
#310215 - 15/05/2008 19:21 Re: EmpegNotifier [Re: AndrewT]
Dearing
Loc: Florida
Windows 95?
_~= Dearing =~_
#310222 - 16/05/2008 05:41 Re: EmpegNotifier [Re: Dearing]
You get a binary (and source) for Windows 2000, XP, 2003, Vista and 2008.
If you don't like it, write your own...
#310223 - 16/05/2008 06:58 Re: EmpegNotifier [Re: Roger]
He's referring to Andrew's comment about not needing to reboot when changing the hosts file. Not that he wants to run it on Windows 95! At least I hope not. If anybody is still running Windows 95 then they should get their head examined IMO...
#310224 - 16/05/2008 07:01 Re: EmpegNotifier [Re: tman]
Ah. Fair enough. My apologies to Dearing; I'm a little short of sleep at the moment, as you can imagine.
#310261 - 17/05/2008 15:15 Re: EmpegNotifier [Re: Roger]
The project page (including downloads) is available at https://projects.differentpla.net/projects/show/empeg-notifier
The https certificate is self-signed, so you'll get a warning. You can safely ignore it (as long as you trust me).
At some point, I'll look into having anonymous access over http, and logged-in access over https.
The current version uploaded there isn't (externally) much further advanced than the one I've already attached. There'll be a new version soon-ish, time permitting.
#310277 - 18/05/2008 08:24 Re: EmpegNotifier [Re: siberia37]
This works (at least, it does for me). You can grab the installer from https://projects.differentpla.net/projects/list_files/empeg-notifier
#310288 - 18/05/2008 18:35 Re: EmpegNotifier [Re: Roger]
oliver
thanks for showing me redmine. for the last week i've been looking at different project trackers, and redmine seems to beat everything else i've looked at.
anyways, one feature i'd like to see supported in EmpegNotifier is... setup a dropbox for autosync when an empeg is located, maybe even as advanced as rsync multiple empegs against a single directory structure.
#310294 - 19/05/2008 02:48 Re: EmpegNotifier [Re: oliver]
EmpegNotifier just runs the defined program. It's up to you what that program does. I was planning on having the default program be responsible for the actual "what do you want to do?" UI.
That said: bung a feature request in on the tracker, and if I get time, I'll put together an external program for syncing.
#310295 - 19/05/2008 02:50 Re: Redmine [Re: oliver]
Yeah. It's not bad; I've been using trac up to this point, which is good, but doesn't support multiple projects too well. Trac's got a better milestone implementation, though.
Getting redmine to run behind Apache was a bit of a chore, though. I'll write up how I did it at some point.
#310411 - 22/05/2008 10:54 Re: Redmine [Re: Roger]
Dearing
Loc: Florida
Yeah, the Windows 95 comment was definitely about the hosts file, not your software. Don't sweat it.
_~= Dearing =~_
#315225 - 18/10/2008 13:02 Re: EmpegNotifier [Re: oliver]
FireFox31
Loc: East Coast, USA
That may be a solution for podcast autosync.
Edited by l0ser (29/10/2008 12:25)
Edit Reason: Fixed link
#322823 - 30/05/2009 15:47 Re: EmpegNotifier [Re: Roger]
I've moved this to Google Code, which will hopefully free up time to actually work on some personal projects, rather than simply tinker with the infrastructure for those personal projects.
http://code.google.com/p/nemplode/
#346614 - 28/07/2011 03:25 Re: EmpegNotifier [Re: Roger]
sirkingchase
Loc: MS,US
Can anyone repost the file?
I can not find this anywhere else on the WHOLE internet, google returns 2 results...
The file listed on the first first is corrupt. I tired opening it in linux and windows with multiple programs to no eval. All other links are broken frown
#346615 - 28/07/2011 08:13 Re: EmpegNotifier [Re: sirkingchase]
No it's not. I just successfully downloaded and opened (and ran) it on Windows 7.
#346616 - 28/07/2011 11:21 Re: EmpegNotifier [Re: Roger]
Is ok for me as well.
#346632 - 30/07/2011 14:01 Re: EmpegNotifier [Re: Roger]
I've recently started using Mercurial for my source control. As such, I've moved all of my repositories to bitbucket. You can find the source to EmpegNotifier in my nemplode repository.
