#334970 - 13/07/2010 15:13
Re: 2 TB hard drive advice wanted
[Re: hybrid8]
I've just reverted my ReadyNAS firmware back to a version that doesn't properly deal with 4k sectors, so I'm likely going to pick up a Seagate 2TB drive instead of the WD. That will be tomorrow at the earliest, so I suppose I still have a day to change my mind, depending on how my ReadyNAS testing goes... Fully agreeing with Mark here Bruno: please, save yourself the agony and DON'T buy Seagate! If you want to stay away from 4K drives completely, there's also still the WD20EA DS drive series which isn't 4K, but also only has 32MB of cache...
#334972 - 13/07/2010 16:00
[Re: Archeon]
It was even usable on the Intel Atom I threw at it. How is that possible? I thought the Atom was a 32 bit CPU? As you say Vail is x64 only? edit: your Atom must be Diamondville or Pineview core then? I ran it on an Acer Aspire R3610, which uses an Intel Atom 330, which is a Diamondville, so yes: it supports x64.
#334973 - 13/07/2010 16:09
[Re: hybrid8]
Perhaps I will take the chance with the WD and apply the patch to change the parking time-out to 30 seconds as well as the jumper to operate in legacy mode. If you can't find a Samsung drive anywhere, I'd take the WD option -with or without jumper hack- any day of the week over Seagate.
#334976 - 13/07/2010 17:55
[Re: Archeon]
Heh, I love how around every 1 to 2 years this board has a hard drive debate. In all the previous threads it seems like there's been one person who, for example, swears by Western Digital because they had 10 Seagate drives fail on them in two years, and then it seems like there's someone with the exact opposite experience. I want to say that Rob R hated Western Digital or something...
I understand why they didn't, but I wish Google had released the results of their hard drive failure analysis. I think they indicated a fairly clear winner.
Anyway, these days I find myself going almost completely by price, as long as it isn't my main drive. Anything valuable is backed up, and anything that isn't is just a minor annoyance when/if it's lost. However, given a choice I'd probably go with Western Digital. They make good products, and their external drives are incredible. I have two 500GB USB drives that are silent from about 1ft.
#334979 - 13/07/2010 18:16
[Re: hybrid8]
Eh. Everybody has different opinions about the various drive manufacturers. I know people that swear by Seagate. Others that are WD only etc...
I personally won't touch a Maxtor drive because I've had so many fail but I've been okay with Seagate. Maxtor was bought out or merged with Seagate so no idea whether I'll trust them now.
IBM/Hitachi were okay and I did even have a few of the Deathstar drives but I've not bought any of their drives recently.
If I had to buy a drive right now then I'd probably get a WD.
- Trevor
#334980 - 13/07/2010 19:07
[Re: hybrid8]
My first hard drives were Connor hard drives. They gave me a lot of grief since two of three drives died after some time of use. Then Seagate bought Connor and I figured, let's give them a try. Bad idea. Another dead drive, but to be honest, a couple of good drives as well (medalist series). So then I tried Maxtor. Worst idea yet. EVERY Maxtor drive I've ever owned failed on me. Then Seagate bought Maxtor. And I started having problems with Seagate (there must be some red line here). Back then, WD was always a bit more expensive than the other brands and I was a poor student, so I still thought with my wallet. But then I thought, more expensive or not, I'll buy a few of those Caviar drives. Best choice yet. I've never had ANY WD drive fail on me. Even though they were a bit more expensive than their competitors (and usually still are, of only a couple of euro!), I thought they and my data were well worth it. I've stayed loyal to the brand up until Samsung started making hard drives and with the F1 drive created a harddisk that was hard to ignore: it was faster, ran cooler and was cheaper than any competing brand. AND they turned out to be excellent drives! I now own 6 of them and none have failed me yet, even though they gave me some problems at first (but that turned out to be the fault of some crappy external enclosure chipset). So since then I've bought Samsung, mainly because they offer so much value for money. But I still love WD too and for this reason I've bought a Velociraptor drive to use as my primary HD last year. That's my story... I'm sure others have different experiences, but many of my friends have the same. Maxtor is the absolute worst. Then Seagate. I've never touched Hitachi since their drives already had problems in the days they were still called IBM. (mainly heat issues and that irrirating creeping sound every so many minutes when the hard drives parked their heads - it seems they never got their act together from what I've read) I'm not saying WD drives or Samsung cannot fail. Of course they can, they are mechanical objects. I AM saying though that with these brands, you'll have the best chance of actually getting your money's worth with drives which will serve you great until YOU decide to replace them with a newer model.
#334981 - 13/07/2010 19:54
[Re: Archeon]
I think it's reasonably obvious that a large portion of this is anecdotal (though not necessarily irrelevant) data. There are, though, a number of noted widespread failures, like the Deathstars and the recent WD Green head-parking issue.
The thing that I've noticed, though, is that no one manufacturer is always the best. I suspect that there's enough cutting-edge engineering going on that it's always a crapshoot when a new model comes out. Part of the problem is that new models seem to be more and more frequent, so that bugs tend not to get worked out over time, and there's not a long enough in-market time for there to be any significant feedback. That is, by the time that the drives die, they're already well into a new model.
At this point, I have absolutely no idea what to get. I've had nasty failures from each of the notable manufacturers, and the couple of new manufacturers scare me. (I can't seem to find references now, but I could swear I saw some boxes not too long ago with brand names I'd never heard of.)
I think the best bet is to run RAID and have, if at all possible, different drives as members, in order to try and prevent coincident failures.
#334982 - 13/07/2010 20:18
Part of the problem is that new models seem to be more and more frequent, so that bugs tend not to get worked out over time, and there's not a long enough in-market time for there to be any significant feedback. That is, by the time that the drives die, they're already well into a new model. I don't entirely agree with that. Hard drives development seems to have stagnated in the last couple of years. Up until a few years, drive sizes were rapidly increasing. It seemed like every so many months, the capacity doubled. That came to a halt once the 1TB barrier was reached. Then everything slowed down considerably. It took a lot of time before the 1.5 TB drives were released, and now 2TB has been the maximum size for quite some time (2 years?). So what are HD manufacturers doing with that 'extra time'? Most of them don't spend it on SSD development, that's for sure. Of all the classical hard drive manufacturers, only Western Digital has now got an SSD (which is not particularly good). Samsung has them too, but that's to be expected from a company which also produces the flash ram chips needed to create such an SSD. I also can't believe the're now spending MORE time on ironing out bugs, because, as you say yourself, there tend to be more bugs plaguing released hardware these days than fewer. So what are they directing their efforts at?
#334983 - 13/07/2010 20:32
[Re: Archeon]
Data density is still increasing -- look at 2.5in drives, which have carried on getting bigger -- but the manufacturers have for some reason been using that headroom to build drives the same capacity with fewer platters, rather than larger capacity. Presumably part of the reason is the thing with traditional partition tables only dealing with drives up to 2TB, but that can't be the whole story (people have had RAID arrays >2TB usable for a while), and you'd still think there'd be a market for capacious (if slow) drives for media servers and so on.
#334984 - 13/07/2010 20:56
[Re: peter]
... and you'd still think there'd be a market for capacious (if slow) drives for media servers and so on. Indeed. Maybe Quantum did have a good point with their Bigfoot series then. Just kidding.
#334985 - 13/07/2010 21:39
[Re: Archeon]
Indeed. Maybe Quantum did have a good point with their Bigfoot series then. Just kidding. You know, I almost mentioned those but decided against it. They got a lot of ridicule for being slow, which they unarguably were, but they had more capacity than anything else on the market. A Bigfoot made in today's technology would be 10-20TB. Peter
#334986 - 13/07/2010 22:15
[Re: Archeon]
Hard drives development seems to have stagnated in the last couple of years. Up until a few years, drive sizes were rapidly increasing. It seemed like every so many months, the capacity doubled. That came to a halt once the 1TB barrier was reached. Then everything slowed down considerably. It took a lot of time before the 1.5 TB drives were released, and now 2TB has been the maximum size for quite some time (2 years?). So what are HD manufacturers doing with that 'extra time'? You're assuming that they can just scale their existing technology forever. The HD manufacturers aren't just going oh well people have enough storage we'll just sit here and wait. The jumps in areal density are because they're introducing new technology to boost the number of bits you can pack onto a platter. The last big jump in storage capacity was because of Perpendicular Magnetic Recording (PMR) being added which significantly reduced the size of each bit. They're getting close to the limits of this technology for HDs and the next generation technology just isn't ready yet. Read this article.
- Trevor
#334987 - 13/07/2010 22:22
[Re: peter]
but the manufacturers have for some reason been using that headroom to build drives the same capacity with fewer platters, rather than larger capacity. Heat dissipation and power consumption is getting to be a big thing these days. The storage appliance people are having trouble with packing in large numbers of drives into enclosures now because of this. As areal density gets higher, the effects of vibration are also getting to be pretty significant. There is video of somebody at Sun with monitoring software running on a SAN that could actually detect somebody making a loud noise nearby from the increase in access time due to vibration. Presumably part of the reason is the thing with traditional partition tables only dealing with drives up to 2TB, but that can't be the whole story (people have had RAID arrays >2TB usable for a while) If PC manufacturers ever move away from the ye olde PC BIOS and on to something like EFI with GPT support then 2TB+ drives wouldn't be a problem.
- Trevor
#334989 - 14/07/2010 06:40
[Re: peter]
...They got a lot of ridicule for being slow, which they unarguably were, but they had more capacity than anything else on the market. A Bigfoot made in today's technology would be 10-20TB.
I'm sure there's still a market for such drives. Their access times were indeed horrible, but that wouldn't matter too much if they would be used for storage/backup of large amounts of data. They would be ideal in video/backup servers. I'm pretty sure I would be interested in buying one of those.
#334990 - 14/07/2010 07:18
[Re: tman]
They're getting close to the limits of this technology for HDs and the next generation technology just isn't ready yet. Read this article. Interesting article! Not very encouraging though... I'm hoping the new technologies will be available soon!
#334991 - 14/07/2010 15:34
[Re: Archeon]
I'm hoping the new technologies will be available soon! In my fantasies I visualize data storage in a piece of crystal the size of a sugar cube, containing petabytes* of data, addressed/accessed by three tiny lasers at mutual right angles. Data transfer speed limited by speed of light considerations. tanstaafl. *Megabyte = 2^20 bytes *Gigabyte = 2^30 bytes *Terabyte = 2^40 bytes *Petabyte = 2^50 bytes *Exabyte. = 2^60 bytes
#334995 - 14/07/2010 22:10
Whatever happened to "Pixie Dust?" I've been trying to Google it but all I find are articles about the future of it (mostly dated 2001-2003), and nothing about what happened. It doesn't appear to be even mentioned on Wikipedia (aside from Tinker Bell).
#334996 - 14/07/2010 22:21
Whatever happened to "Pixie Dust?" I've been trying to Google it but all I find are articles about the future of it (mostly dated 2001-2003), and nothing about what happened. It doesn't appear to be even mentioned on Wikipedia (aside from Tinker Bell). "Pixie dust" = Antiferromagnetically-Coupled media It has already been implemented.
- Trevor
#335101 - 18/07/2010 13:31
Anyway, these days I find myself going almost completely by price, as long as it isn't my main drive. Anything valuable is backed up, and anything that isn't is just a minor annoyance when/if it's lost. Here in the UK I go by "who offers an advance-replacement warranty". Currently only Samsung AFAIK. I figure that most of the errors are a few bad blocks and usually part of a RAID - I want the replacement drive around before I pull the failing disk and do a ddrescue on it.
Running twin 30's
#335157 - 20/07/2010 02:14
[Re: hybrid8]
Now I'm wrestling with abysmal performance on my ReadyNAS. I'm talking about writes of less than 10MB/s (often between 1 and 4 MB/s) and reads from 6 to 30MB/s depending on what's being read... Are you sure you actually got the head parking issue resolved? Have you checked your LCC (Load Cycle Count) to see if it is a reasonable number and the WIDLE3 program did what it was supposed to do? tanstaafl.
