#170030 - 10/07/2003 09:28
mp3tofid on Mac OS X
Hi,
I found on Google that someone has ported mp3tofid to Mac OS X, and in the way fixed some endian issues.
This darn x86 linux programmer would love to share these fixes so he does not have to make the same mistakes in an upcoming release.
So, send them in, please.
Thanks,
Pim
#170032 - 10/07/2003 10:10
Re: mp3tofid on Mac OS X
[Re: tonyc]
What got you to Googling for this?
For this audience, I narrowed down the search to come up with only one result. (Is that Googlewhacking?). I found this just by searching for mp3tofid.
Was it that burning sensation in your ears that you get when someone's talking about you behind your back?
Yeah, something like your name being part of the answer in a quiz, and you're not there to see it :-)
Pim
#170033 - 10/07/2003 20:27
[Re: pim]
Since mp3tofid isn't a real word, you can't consider that a googlewhack. I think I've only ever been able to come up with one solid one.
#346288 - 07/07/2011 20:34
[Re: pim]
Did we ever track down the changes need to make it work on OSX ?
I've just tried to build the current version, with no luck.
#346292 - 07/07/2011 22:03
[Re: andy]
I put a more more effort into trying to build it...
Installed a whole bunch of libraries with MacPorts, tweaked some include/lib paths, added the odd extra include (sys/dir.h), created byteswap.h etc etc
But I still can't get it to build. I am stuck at:
cc -O2 -g -I/opt/local/include -L/opt/local/lib -Wall -Wpointer-arith -Wbad-function-cast -Wcast-align -Wnested-externs -c -o mp3tofid.o mp3tofid.c mp3tofid.c: In function ‘sourcefiletofidnumber’: mp3tofid.c:464: warning: format ‘%lu’ expects type ‘long unsigned int’, but argument 5 has type ‘ino_t’ mp3tofid.c:466: warning: format ‘%lu’ expects type ‘long unsigned int’, but argument 7 has type ‘ino_t’ mp3tofid.c: In function ‘dirscan’: mp3tofid.c:939: warning: passing argument 4 of ‘scandir’ from incompatible pointer type cc -O2 -g -I/opt/local/include -L/opt/local/lib -Wall -Wpointer-arith -Wbad-function-cast -Wcast-align -Wnested-externs -c -o scanmp3.o scanmp3.c cc -O2 -g -I/opt/local/include -L/opt/local/lib -Wall -Wpointer-arith -Wbad-function-cast -Wcast-align -Wnested-externs -c -o scanwave.o scanwave.c cc -O2 -g -I/opt/local/include -L/opt/local/lib -Wall -Wpointer-arith -Wbad-function-cast -Wcast-align -Wnested-externs -c -o scanwma.o scanwma.c cc -O2 -g -I/opt/local/include -L/opt/local/lib -Wall -Wpointer-arith -Wbad-function-cast -Wcast-align -Wnested-externs -c -o scanvorbis.o scanvorbis.c /opt/local/include/vorbis/vorbisfile.h:75: warning: ‘OV_CALLBACKS_DEFAULT’ defined but not used /opt/local/include/vorbis/vorbisfile.h:82: warning: ‘OV_CALLBACKS_NOCLOSE’ defined but not used /opt/local/include/vorbis/vorbisfile.h:89: warning: ‘OV_CALLBACKS_STREAMONLY’ defined but not used /opt/local/include/vorbis/vorbisfile.h:96: warning: ‘OV_CALLBACKS_STREAMONLY_NOCLOSE’ defined but not used cc -O2 -g -I/opt/local/include -L/opt/local/lib -Wall -Wpointer-arith -Wbad-function-cast -Wcast-align -Wnested-externs -c -o scanflac.o scanflac.c cc -O2 -g -I/opt/local/include -L/opt/local/lib -Wall -Wpointer-arith -Wbad-function-cast -Wcast-align -Wnested-externs -c -o iconv.o iconv.c cc -g -L/opt/local/lib -o mp3tofid mp3tofid.o scanmp3.o scanwave.o scanwma.o scanvorbis.o scanflac.o iconv.o -lpopt -lgdbm -lcrypto -lmad -lid3tag -lvorbisfile -lvorbis -logg -lsndfile -lFLAC -lz -lm Undefined symbols: "_libiconv", referenced from: _codesetconv in iconv.o _codesetconv in iconv.o "_libiconv_open", referenced from: _eiconv_open in iconv.o ld: symbol(s) not found collect2: ld returned 1 exit status make: *** [mp3tofid] Error 1
Any clues anyone ? It is a long time since I was messing about getting random Unix code to build...
#346293 - 07/07/2011 23:31
[Re: andy]
I've just tried to build the current version, with no luck. Why does this even need compiling -- wouldn't a shell script make more sense?
#346304 - 08/07/2011 02:41
[Re: Daria]
#346309 - 08/07/2011 05:26
[Re: Daria]
Awesome. Builds perfectly, one I worked out I was pulling the wrong branch Thanks
#346488 - 18/07/2011 22:56
If I would write it again, I'd use Python. I have been considering a rewrite once and then but never got to it. Pim
#346489 - 18/07/2011 23:10
[Re: Daria]
Cool. I do own a (Intel) Mac Mini, so I can try this out. Are all the required libraries available as binaries? I once planned to buy a PPC Mac Mini, and starting coding some byte swap stuff but never finished it as I never bought one. Thanks for putting mp3tofid into github. Can I get read/write access there? I suppose I could merge most of the changes into master. Pim
#346494 - 19/07/2011 09:47
[Re: pim]
Cool. I do own a (Intel) Mac Mini, so I can try this out. Are all the required libraries available as binaries? I once planned to buy a PPC Mac Mini, and starting coding some byte swap stuff but never finished it as I never bought one. Thanks for putting mp3tofid into github. Can I get read/write access there? I suppose I could merge most of the changes into master. I tried and failed to guess your github username. Just let me know who to add. As to libraries, I used macports to build what was needed. I believe they distribute them in binary form, also, but I haven't used them, so I can't tell you how to get them.
#346497 - 19/07/2011 14:05
[Re: Daria]
pimzand
It did not exist when you tried.
Thanks, Pim
#346524 - 20/07/2011 15:25
[Re: Daria]
Im just a beginner with git.
I was hoping the distributed workflow stuff that git does would allow a dynamic read-only link to another repo.
Pim
#346531 - 20/07/2011 19:18
[Re: pim]
I was hoping the distributed workflow stuff that git does would allow a dynamic read-only link to another repo I'm not 100% sure what you mean by this. Generally the distributed stuff is done by each developer having a private repository, and a public-facing repository. If Joe wants changes from Alice, he pulls them from her public repository, into his private repository. When he has changes that he wants to make public to Alice, he pushes his changes from his private repository into his public repository. The project maintainer will generally maintain the "master" public repository by pulling changesets from the contributors' public repositories. You can pull from multiple repositories, without ever pushing anything back, so in effect, everything is a dynamic read-only link in that regard. git also has the notion of a submodules, which allows you to create a directory in your tree, and associate that with a particular revision of some other repository. This is what gives you the ability to track dependencies between projects. When you "check out" a git repo containing a submodule, the submodule isn't automatically checked out.
#346535 - 21/07/2011 02:10
[Re: pim]
Pim yeah, that would be a tracking repo.
