#350960 - 18/03/2012 02:54 Original tuner won't tune
WBK
Loc: Nashville TN
I have two original tuners and neither will respond to tune a station.
The red led is on and I've tried both on two different units/sleds. Tuner #1 was used for a while but has been stored for years .When tuner #2 failed I swapped in #1 with the same result.I just installed a new hard drive in my spare empeg and neither tuner will tune. Either tuner is recognized but just sits on 520 khz or 87.9 mhz.
Any ideas?
#350963 - 18/03/2012 11:57 Re: Original tuner won't tune [Re: WBK]
What are you doing to "tune" -- perhaps you've simply forgotten how to use the empeg tuners (not 100% intuitive)?
#350964 - 18/03/2012 14:46 Re: Original tuner won't tune [Re: mlord]
WBK
Loc: Nashville TN
By tune I mean change stations by using the right or left buttons.
A short right press will scroll through presets (A1,A2,etc) but a long press will not cause the tuner to move off of 87.9.
#350965 - 18/03/2012 15:16 Re: Original tuner won't tune [Re: WBK]
#350970 - 18/03/2012 18:40 Re: Original tuner won't tune [Re: larry818]
If you have Hijack installed, then a short press of the Knob should activate the Hijack PopUp functions, one of which is KnobSeek. This (temporarily) turns the Knob into a manual tuning dial, for simple, intuitive use of the radio. smile
#351021 - 21/03/2012 00:16 Re: Original tuner won't tune [Re: mlord]
WBK
Loc: Nashville TN
That was it, using version 2.0 final. I must have been using 2.0 beta 13 for the last ten years and forgotten. That was a dozen computers and a wife or two ago.
Thanks!
