#365732 - 09/01/2016 20:47 Still can't shake these segfault errors...
FieroSTi
So over the summer I tried for months on end to get a single 256GB mSATA card with a JMircon IDE-Sata bridge to work in the empeg. It worked well until I would hit about 100GB of fids on the device, then emplode and jemplode would do nothing but crash the unit, giving me a "0000.7 segfault err" every time. I never solved this issue with the SSD. I swapped in two 160GB Seagate drives, for a total of 320GB. Now I experience the same issue with the two spinning drives. Just over 100GB of fids cripples the unit. I've tried a new IDE cable, checked the IDE header and just about everything else I can think of. I cannot get the unit to recover from these errors. I can fsck both drives and the error will return during the next sync.
Having said that, If I get into the shell, I can move the existing fids folders worth 100GB+ to fids-bak or similar, create new fids folders, blow up the database, playlists and tags files; then sync with emplode or jemplode with success. Definitely seems to be a database size or memory limitation. I'm running mp3tofid on my entire library now to see if it's just an issue with building the databases. I'll transfer everything over when that's done to see if maybe mp3tofid can make database files that work.
I also captured a log. I included everything just in case there's an error earlier on in the boot cycle that somebody may recognize. The crash is down at the end. Any thoughts?
empeg-car bootstrap v1.00 20000601 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v508 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Fri Jan 9 16:06:35 EST 2009
Checking for extra DRAM:
c0c00000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 7, serial number 80000481) 12MB DRAM
Command line: mem=12m
Memory: 10944k/12M available (996k code, 20k reserved, 324k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x9e754
Tuner: loopback=0, ID=-1
show_message("Hijack v508 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005a80).
empeg RDS driver initialised
RAM disk driver initialized:  16 RAM disks of 4096K size
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xff80
ide_data_test: wrote 0xffff read 0xff80
ide_data_test: wrote 0xaaaa read 0xaa80
ide_data_test: wrote 0x5555 read 0x5580
ide_data_test: wrote 0x0000 read 0xff00
ide_data_test: wrote 0xffff read 0xff00
ide_data_test: wrote 0xaaaa read 0xaa00
ide_data_test: wrote 0x5555 read 0x5500
hda: ST9160821A, ATA DISK drive
hdb: ST9160821A, ATA DISK drive
hda: ST9160821A, 152627MB w/8192kB Cache, CHS=19457/255/63, LBA48
hdb: ST9160821A, 152627MB w/8192kB Cache, CHS=19457/255/63, LBA48
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:e1
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Timezone: EST
hijack: removed menu entry: "Serial Port Assignment"
kftpd: listening on port 21
khttpd: listening on port 80
ktelnetd: listening on port 23
Using non-standard cache size 36 (bonus 0Mb, adjustment 48)
  player.cpp        : 385:empeg-car 2.01 2004/07/06.
! tags.cpp          :  61:Failed to open tags (0xc0041002).
show_message("0000.7 segfault err")
player(8): user memory violation at pc=0x020e1888, lr=0x696c6f50 (bad address=0x4026c000, code 0)
pc : [<020e1888>]    lr : [<696c6f50>]
sp : bffff7a0  ip : 20706f48  fp : bffff7bc
r10: 00000000  r9 : bffffc24  r8 : 00000000
r7 : 00000018  r6 : 00000008  r5 : 20706948  r4 : 28206563
r3 : 5020706f  r2 : 00000008  r1 : 0215319c  r0 : 4026bff8
Flags: Nzcv  IRQs on  FIQs on  Mode USER_32  Segment user
Control: D034917D  Table: D034917D  DAC: 00000015
Function entered at [<020e17dc>] from [<020e16a4>]
 r7 = 4026BFFB  r6 = 4026BFFC  r5 = 02153199  r4 = 00000020
Function entered at [<020e1630>] from [<0207cc44>]
 r7 = BFFFFC60  r6 = 02153198  r5 = 00000021  r4 = BFFFFC60
Function entered at [<0207cbf4>] from [<0205642c>]
 r6 = 02135B80  r5 = 0214DA74  r4 = 00000000
Function entered at [<020560b0>] from [<0206189c>]
 r10 = 00000000  r9 = 02112594  r8 = 0214DA68  r7 = BFFFFC60
 r6 = 00000000  r5 = 02174458  r4 = 0000155E
Function entered at [<020617c0>] from [<020322fc>]
 r7 = BFFFFD0C  r6 = BFFFFD04  r5 = 0214F1AC  r4 = 02174448
Function entered at [<02032258>] from [<0200881c>]
 r6 = BFFFFD08  r5 = 0214F1A4  r4 = BFFFFD04
Function entered at [<020087e4>] from [<0202fcbc>]
 r5 = BFFFFD04  r4 = BFFFFD10
Function entered at [<0202fa0c>] from [<0202f758>]
 r10 = BFFFFEE4  r9 = 00000001  r8 = 0214DA68  r7 = BFFFFEE8
 r6 = 00000024  r5 = BFFFFD78  r4 = BFFFFD78
Function entered at [<0202f718>] from [<020316bc>]
 r6 = 00000024  r5 = FFFFFFFF  r4 = BFFFFD78
Function entered at [<02031464>] from [<020317ec>]
 r10 = 02031788  r9 = 00000000  r8 = 02112280  r7 = 00000000
 r6 = 020000C0  r5 = 00000001  r4 = BFFFFF64
Function entered at [<02031788>] from [<020c90c4>]
 r5 = BFFFFF64  r4 = 00000001
Function entered at [<020c8fe8>] from [<02000104>]
 r10 = 00000000  r8 = 00000000  r7 = 00000000  r6 = 00000000
 r5 = 00000000  r4 = 00000000
Restored terminal settings
Abnormal player termination
Player received signal 11
Starting player
Timezone: EST
Edited by FieroSTi (09/01/2016 22:58)
#365733 - 09/01/2016 23:02 Re: Still can't shake these segfault errors... [Re: FieroSTi]
There are all kinds of hacks and things required to manage a very large number of FIDs. How many FIDs do you have (as opposed to the 100GB+ storage space they require) ?
I'm not "one with" the search engine here, but most others manage it just fine, and there are some good threads on dealing with big (for the empeg) drives.
One possible starting place is to search for "set_empeg_max_fid".
#365734 - 09/01/2016 23:22 Re: Still can't shake these segfault errors... [Re: FieroSTi]
FieroSTi
Ahh, yes. I remember reading about set max fid, but frankly had forgotten about it as I didn't think I was at that limit. How do I find the number of fids that I have? Where can I find a copy of set_empeg_max_fid.v7? I've been searching for the last 15 minutes or so and can't find the actual script...
Edited by FieroSTi (09/01/2016 23:44)
#365738 - 10/01/2016 14:58 Re: Still can't shake these segfault errors... [Re: FieroSTi]
A "FID" is just a file, eg. an .mp3 track or a playlist. On the player's drive(s), they have their own fids directories.
So just count those to see how many.
The set_max_fid program (written in C) is available (I'm attaching it here), but you may have different issues. Really, try and find the long threads here that deal with managing players with loads of FIDs and large drives.
set_empeg_max_fid.v7 (359 downloads)
Description: set_empeg_max_fid.v7 binary for the empeg.
#365773 - 14/01/2016 21:32 Re: Still can't shake these segfault errors... [Re: FieroSTi]
FieroSTi
Thanks, Mark. I got that uploaded and installed and verified the new maximum fid count. Something like 44,000 and change it ended up. I haven't gotten a chance to re-fill my drives and check for lack of crashing, but I'm up and running again anyway.
