empeg-car bootstrap v1.00 20000601 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v508 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Fri Jan 9 16:06:35 EST 2009
Checking for extra DRAM:
c0c00000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 7, serial number 80000481) 12MB DRAM
Command line: mem=12m
Memory: 10944k/12M available (996k code, 20k reserved, 324k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x9e754
Tuner: loopback=0, ID=-1
show_message("Hijack v508 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005a80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xff80
ide_data_test: wrote 0xffff read 0xff80
ide_data_test: wrote 0xaaaa read 0xaa80
ide_data_test: wrote 0x5555 read 0x5580
ide_data_test: wrote 0x0000 read 0xff00
ide_data_test: wrote 0xffff read 0xff00
ide_data_test: wrote 0xaaaa read 0xaa00
ide_data_test: wrote 0x5555 read 0x5500
hda: ST9160821A, ATA DISK drive
hdb: ST9160821A, ATA DISK drive
hda: ST9160821A, 152627MB w/8192kB Cache, CHS=19457/255/63, LBA48
hdb: ST9160821A, 152627MB w/8192kB Cache, CHS=19457/255/63, LBA48
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman ([email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:e1
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Timezone: EST
hijack: removed menu entry: "Serial Port Assignment"
kftpd: listening on port 21
khttpd: listening on port 80
ktelnetd: listening on port 23
Using non-standard cache size 36 (bonus 0Mb, adjustment 48)
player.cpp : 385:empeg-car 2.01 2004/07/06.
! tags.cpp : 61:Failed to open tags (0xc0041002).
show_message("0000.7 segfault err")
player(8): user memory violation at pc=0x020e1888, lr=0x696c6f50 (bad address=0x4026c000, code 0)
pc : [<020e1888>] lr : [<696c6f50>]
sp : bffff7a0 ip : 20706f48 fp : bffff7bc
r10: 00000000 r9 : bffffc24 r8 : 00000000
r7 : 00000018 r6 : 00000008 r5 : 20706948 r4 : 28206563
r3 : 5020706f r2 : 00000008 r1 : 0215319c r0 : 4026bff8
Flags: Nzcv IRQs on FIQs on Mode USER_32 Segment user
Control: D034917D Table: D034917D DAC: 00000015
Function entered at [<020e17dc>] from [<020e16a4>]
r7 = 4026BFFB r6 = 4026BFFC r5 = 02153199 r4 = 00000020
Function entered at [<020e1630>] from [<0207cc44>]
r7 = BFFFFC60 r6 = 02153198 r5 = 00000021 r4 = BFFFFC60
Function entered at [<0207cbf4>] from [<0205642c>]
r6 = 02135B80 r5 = 0214DA74 r4 = 00000000
Function entered at [<020560b0>] from [<0206189c>]
r10 = 00000000 r9 = 02112594 r8 = 0214DA68 r7 = BFFFFC60
r6 = 00000000 r5 = 02174458 r4 = 0000155E
Function entered at [<020617c0>] from [<020322fc>]
r7 = BFFFFD0C r6 = BFFFFD04 r5 = 0214F1AC r4 = 02174448
Function entered at [<02032258>] from [<0200881c>]
r6 = BFFFFD08 r5 = 0214F1A4 r4 = BFFFFD04
Function entered at [<020087e4>] from [<0202fcbc>]
r5 = BFFFFD04 r4 = BFFFFD10
Function entered at [<0202fa0c>] from [<0202f758>]
r10 = BFFFFEE4 r9 = 00000001 r8 = 0214DA68 r7 = BFFFFEE8
r6 = 00000024 r5 = BFFFFD78 r4 = BFFFFD78
Function entered at [<0202f718>] from [<020316bc>]
r6 = 00000024 r5 = FFFFFFFF r4 = BFFFFD78
Function entered at [<02031464>] from [<020317ec>]
r10 = 02031788 r9 = 00000000 r8 = 02112280 r7 = 00000000
r6 = 020000C0 r5 = 00000001 r4 = BFFFFF64
Function entered at [<02031788>] from [<020c90c4>]
r5 = BFFFFF64 r4 = 00000001
Function entered at [<020c8fe8>] from [<02000104>]
r10 = 00000000 r8 = 00000000 r7 = 00000000 r6 = 00000000
r5 = 00000000 r4 = 00000000
Restored terminal settings
Abnormal player termination
Player received signal 11
Starting player
Timezone: EST
