#36689 - 16/08/2001 16:57 New Emplode Feature
avatarTX
Loc: Dallas Texas USA
I dont know if this has been requested or not but I would like to see it. I do realise that to impliment something like this would have to wait for a major software revision.. but hey, I will wait.
I can only guess at the way the current database is designed.. but I would like to see a way to add a song to multiple playlists while only having to upload the song once. Some songs on my empeg fit in more than one playlist.. and the song is taking up disk space twice.
For the sake of example, lets call each song upload a record in a database. Would it not be simple enough to have a field in each record of the database for each playlist? That way when I upload a song, I could flag each playlist I want the song to appear in.. and only have the song uploaded once.
I do see that it would be hard to add a playlist field to each record later on.. but there is bound to be some solution to this issue, isn't there?
Carl
080000506 12gb-green
Carl Aydelotte Dallas Texas USA empeg MKII 080000506 40gb-green
#36690 - 16/08/2001 17:13 Re: New Emplode Feature [Re: avatarTX]
Greetings!
Uh, that is already there. In emplode, you can upload the song, and then drag the song (holding down the control key) to drop it into another list. Done. You will see a little "+" sign as you drag it. Just like Windows 2000... Only 1 copy is uploaded, but you can move or delete these pointers independently. When the last one is removed, the file is deleted.
Paul G.
SN# 090000587 (96GB Smoke)
#36691 - 16/08/2001 23:43 Re: New Emplode Feature [Re: pgrzelak]
muzza
In addition to this, if you copy a playlist around you only have to modify the playlist contents and all the other copies are updated.
I hope you haven't sent duplicate songs to the empeg. I have started copying songs from the original album into soundtrack albums if there are the same version. This maximises the space while still giving you all the songs. It does affect tweak order things tho.
Murray 06000047
ust increasing my post count
#36692 - 17/08/2001 00:55 Re: New Emplode Feature [Re: pgrzelak]
avatarTX
AHA! I did not know that. This will make things MUCH easier for me. Thanks for the quick tip!
Carl
#36693 - 17/08/2001 10:00 Re: New Emplode Feature [Re: avatarTX]
This is covered pretty specifically in the FAQ.
You might want to spend a few minutes and dig through the FAQ. Maybe there's other nuggets of helpful information in there?
#36694 - 19/08/2001 13:09 Re: New Emplode Feature [Re: tfabris]
avatarTX
Yeah, I see it now. Ooops!
By nature, I am one of those guys that gets it home and takes it out of the box, plugs it in and turns it on without ever reading the instructions.. nothing wrong with playng with it to figure it out except that I always seem to miss something like that in the documentation.
Carl
