#38567 - 15/09/2001 22:10 thumps & grumps
jwickis
Loc: India
Does anyones tuner thump when switching sources?
I get a grumble or thump when the tuner is just starting up after being switched from player to tuner.
#695-Mk2/8 colors-12Gig/TUNER- awaits v2.x & Voice Recog.
#38568 - 16/09/2001 11:12 Re: thumps & grumps [Re: jwickis]
Doesn't happen on my tuner. Anyone else?
Wiring problems, possibly?
#38569 - 16/09/2001 11:35 Re: thumps & grumps [Re: tfabris]
jwickis
Loc: India
No it's not the wiring as it only happens when switching from MP3 source to Tuner source using the remotes SRC button for source switching, never happened when switching w/o tuner. The thump or grumble describes it better, is only about a 1/2 second but if the volume is loud when switching sources the sound is really irritating. It's almost like the tuner is finding the frequency it was last on or the tuner is switching on.
I'm going to try it later using the menu switching to see if it does it then as well.
#38570 - 16/09/2001 15:57 Re: thumps & grumps [Re: jwickis]
jwtadmin
Loc: Ipswich, MA
I get the same Thump when switching via the menu
___ John Turner "It's easier to ask for forgiveness than to ask for permission"
#38571 - 17/09/2001 22:44 Re: thumps & grumps [Re: jwickis]
ProtonVehiCROSS
I have exactly the same issue. Generally it happens when the Rio Car is turned on already waiting to go in radio mode. As soon as the radio starts, there's a short 1/2 second rumble as the tuner module powers up. I thought it was normal tuner behavior as it powers up... this never happens with "player" mode.
[yellow]
________________
Grant Eaton
ProtonVehiCROSS
[/yellow]
#38572 - 18/09/2001 03:15 Re: thumps & grumps [Re: ProtonVehiCROSS]
This does sound like a bug, we'll get it fixed for 2.0
#38573 - 18/09/2001 15:00 Re: thumps & grumps [Re: altman]
ProtonVehiCROSS
Yes, I think it could be fixed by adding a 1/2 second delay before audio is turned on. This would give sufficient time for the tuner to finish powering up, which is what it sounds like is happening.
[yellow]
________________
Grant Eaton
ProtonVehiCROSS
[/yellow]
#38574 - 18/09/2001 15:18 Re: thumps & grumps [Re: ProtonVehiCROSS]
Is it possible that the sound you're hearing is your antenna amplifier powering up?
