#50782 - 21/12/2001 08:52 deleted marked mp3 and space stays same?
silvercas
so ive marked a bunch of mp3's and deleted them. they had to equal at least 150 megs or so. But the space stayed the same after a resynch. I even added a couple and it dropped from 18.3->18.2 gigs. what gives?
#50783 - 21/12/2001 09:29 Re: deleted marked mp3 and space stays same? [Re: silvercas]
Fastrack
Loc: Toronto, Ontario Canada
Did you delete these files from the "All Tracks" View as well!? Or the other soup views? Or just the Playlist?
Ben Rio Car 10GB + 60GB Toshiba ([green]Green[/green]) - Serial # 30102833
#50784 - 21/12/2001 10:36 Re: deleted marked mp3 and space stays same? [Re: Fastrack]
silvercas
ta da.. lI only did it from the playlist.. just did it from all tracks and its gone.. THANKS wow why so hard :)
#50785 - 21/12/2001 11:43 Re: deleted marked mp3 and space stays same? [Re: silvercas]
wow why so hard
This was an architectural change in Emplode. The confusion will be solved in the next release by a redesigned file-deletion dialog box.
