Good hello. Decided to post this
cross-link to a perceived issue WRT 2.00-beta7 and kicking in the Power Antenna lead for AM radio
only. The aforementioned link provides info for starters.
If there's something I can do on my end to determine, via software, if all is well or not, please advise! Happy to help.
Meanwhile, some stats on the
Auto Antenna Booster Amplifier:
Booster body: 18mm; Antenna cable length: 300mm; Power length: 500mm; Freq. Response typical for FM/AM/SW/LW frequency ranges; Voltage: DC12V; Power Consumption: Less than 10mA; Electrostatic Capacitance: 80pf.
A postscript to my original post on this subject: "Nice 'n strong" is still weaker than what my factory unit was able to pull in, but regardless it's still stronger than it was before 2.00-beta7. So you could argue it's a tuner positioning issue at this point, or that the antenna booster is just lousy.
![](/images/icons/wink.gif)
