Page 3 of 3 < 1 2 3
#57144 - 14/01/2002 11:24 Re: Hijack v119: MUCH faster directory listings [Re: mlord]
mandiola
So far today i've been messing around with picker | emptris | disp ...etc... I made a short menu system that you can choose to play emptris or run other programs,etc... and goes away after the timeout if no buttons are pressed... Now is there any easy way I could get this to load when a certian button or something is pressed?
I know this is probobly the worst way of doing it but it was the only way I could think without writing programs that needed to be compiled myself to run programs like emptris for other people to play while in the car...
-Greg
#57145 - 16/01/2002 08:53 Re: Hijack v114: major bug fixed [Re: mlord]
Dava
Loc: Bucks UK
Mark,
I have just tried the initial.C again with V127.... No luck.
I tried to disable your "Restore DC Visuals" just in case this was the cause but it still does not seem to do these commands at startup on DC.
Did you attempt a fix back around v116?
MK2 smoked 32Gb S/n 090000949 MK2a Blue 20GB racked and out of sync
#57146 - 17/01/2002 16:39 Re: Hijack v114: major bug fixed [Re: Dava]
Okay, the .C and .H should now be working as advertised.. Hijack v132.
Page 3 of 3 < 1 2 3
