#64498 - 29/01/2002 16:38 Didn't know I needed a amp...
KeefTM
Ok, so I need to get an amp. I'm just looking for one that would work. (money is kind of tight) So what should I go with? And I've installed head units before, how much harder is it to install an amp? And what is the white connector out of the back for? Sorry if these are newbie questions, I'm just a little lost right now. Thanks..
#64499 - 29/01/2002 17:03 Re: Didn't know I needed a amp... [Re: KeefTM]
ithoughti
Loc: Boston, MA USA
Don't worry Tony I got this one...
Try reading the FAQ to answer some of your questions, and then if you can't find what you need, come back and ask some questions.
//matt
//matt
#64500 - 29/01/2002 17:13 Re: Didn't know I needed a amp... [Re: KeefTM]
Installing an amp is more difficult than installing a head unit because you have to run wires to your trunk, and preferably through the firewall to your car's battery. You can get kits from Crutchfield with all the necessary wiring.
The white connector is for the tuner module.
#64501 - 29/01/2002 17:34 Re: Didn't know I needed a amp... [Re: tfabris]
KeefTM
Well, I already know of a hole in the firewall, so I shouldn't have to much trouble. Thanks for the help. That white connector was cofusing me!
