#66251 - 03/02/2002 17:18 NEW: autoHijack
Gary
Attached is a script that will automatically check for upgrades of Hijack, download the latest, and then flash it to your empeg.
Basically, it's a Mark Lord tracker: a solution for those of us who have trouble keeping up with Mark's prolific coding of the excellent Hijack. (Thanks, Mark, for releasing 5 or 6 upgrades this weekend while I was coding so I could test...)
After setting it up, you can just click on the icon and you're done. If your kernel is current, nothing happens; if there's a newer one, it's installed. Error reporting is extensive, downloads are saved, and there's a facility for rolling your kernel back to the last one that successfully flashed. Flashed kernels are verified against the downloaded zImage file.
You need Python and a working Hijack kernel. Tested on WinXP, but should be portable.
First contribution; let me know how it works for you. Comments/suggestions/rants welcome.
Gary
[Edit: The latest version is attached to one of my messages below; please scroll down...]
64674-autoHijack_v3.zip (62 downloads)
Edited by Gary (03/02/2002 21:29)
#66252 - 03/02/2002 17:32 Re: NEW: autoHijack [Re: Gary]
I've been thinking of adding this to my linux script, how did you easially detect newer versions on the web site?
Nevermind, I just looked at the source code,
Edited by Drakino (03/02/2002 18:29)
#66253 - 03/02/2002 18:09 Re: NEW: autoHijack [Re: Gary]
Nosferatu
Loc: France, Champagne
ahh, I tried to do the same in Perl but I had no doc on how to use IP socket in Perl to dowload kernels on Mark's Website .
Good Work !!!!
Empeg IIa - 10 Gb - Red Fascia - Tuner, the day is coming - I Will Strike From the Grey -
#66254 - 03/02/2002 18:33 Re: NEW: autoHijack [Re: Gary]
ClownBurner
Loc: Irvine, CA USA
Wow, that's neat... Saves me the trouble of hacking out a perl version.
Thanks!
_____________ James Mancini
#66255 - 03/02/2002 20:25 Re: NEW: autoHijack [Re: Gary]
Yang
Loc: Raleigh, NC
I get this:
Traceback (most recent call last):
File "D:\Empeg\AutoHijack\autoHijack.py", line 345, in ?
new_kernel_file = check_for_latest_file()
File "D:\Empeg\AutoHijack\autoHijack.py", line 240, in check_for_latest_file
if newer_kernel_on_web(zImage_filename) or GL_overwrite_downloaded_kernels:
File "D:\Empeg\AutoHijack\autoHijack.py", line 211, in newer_kernel_on_web
if version(zimage_on_web) > version(disk_zImages[0]):
IndexError: list index out of range
When I run it... looks like it can't handle being run for the first time..
Edit: I had to comment out lines 211,214-216 and reduce the tab of 212-213 to get it to work the first time, if anyone else has this problem.. Once you have one done successfully it'll work ok.
Edited by Yang (03/02/2002 20:30)
#66256 - 03/02/2002 21:22 Re: NEW: autoHijack [Re: Yang]
Gary
Roger that. The error occurs if the working directory is empty. Here's a new version with a fix. Also fixed in this version: changing your ip address will no longer upset the database that stores the last successful upload.
64738-autoHijack_v4.zip (54 downloads)
#66257 - 03/02/2002 22:44 Re: NEW: autoHijack [Re: Gary]
Terminator
Loc: Dallas, TX
Thanks for your work on this program. It works!
Sean
#66258 - 06/02/2002 09:32 Re: NEW: autoHijack [Re: Gary]
ClownBurner
Loc: Irvine, CA USA
Here's a minor tweak...
Your source mentions that you want to pause the player but can't, because sending a play/pause will UNPAUSE the player if it's already paused... But what about standby?
Replace line 300 with:
ftp.sendcmd('SITE button source.L')
and the Empeg will be placed in sleepy-mode.. On my Empeg, it doesn't seem to wake it if it's already in standby, but it will reliably put it there.
