#70768 - 13/02/2002 10:31 Fitting problems.
MaximaJed
I have a 98 Nissan Maxima. I tried to install my Rio car unit in, but it does not fit in the stock console piece. Has anyone else installed one in the same car?
#70769 - 13/02/2002 17:22 Re: Fitting problems. [Re: MaximaJed]
in what way doesn't it fit ?
#70770 - 13/02/2002 19:17 Re: Fitting problems. [Re: msaeger]
MaximaJed
The docking sled doesn't really fit. And also the rio car face seems to big. The screws on the side seem to get stuck.
#70771 - 19/02/2002 14:40 Re: Fitting problems. [Re: MaximaJed]
jnmunsey
Loc: Houston, TX, USA
From what I have ready the Rio is a little wider than most DIN sized stereos, and possibly the Maxima is a little narrower than most cars - this is a bad combo.
Supposedly you will have to shave the plastic on the Max.
I have a Max and am waiting to install my RioCar but am gathering all info first..
#70772 - 21/02/2002 03:21 Re: Fitting problems. [Re: jnmunsey]
justinlarsen
Loc: Petaluma, CA
or cut the mounting cage like i have done. fits like a glove now
---- Justin Larsen
#70773 - 22/02/2002 14:50 Re: Fitting problems. [Re: justinlarsen]
MaximaJed
I can't even fit the rio by itself cause of the plastic in from. How do I go about shaving the plastic? Use a dremel of a tool like it?
#70774 - 22/02/2002 14:56 Re: Fitting problems. [Re: MaximaJed]
Ezekiel
Loc: NH USA
I used a dremel tool for my Subaru Forrester install, just go slowly and carefully as it's hard to put the material back on.
-Zeke
WWFSMD?
#70775 - 22/02/2002 15:29 Re: Fitting problems. [Re: Ezekiel]
tracerbullet
Loc: Minnesota
And when you get "pretty close" to how you want it, use a block and some sandpaper and you'll get a nice straight edge.
#70776 - 23/02/2002 11:26 Re: Fitting problems. [Re: tracerbullet]
MaximaJed
Ok thanks for the info guys.
#70777 - 27/02/2002 20:03 Re: Fitting problems. [Re: MaximaJed]
MaximaJed
Well I borrowed a dremel from my friend, man that thing is an amazing tool. Shaved off about 1/4 of an inch on both sides and it fits perfectly now. I should have drilled into the sled, but i just used the tabs. Seems pretty steady in place and all. But should it be difficult to pull out when I try and take it out?
#70778 - 03/03/2002 19:15 Re: Fitting problems. [Re: MaximaJed]
jnmunsey
Shaved 1/4 inch from each side fo your dash console?
So, does thise mean no modification is needed to the cage assembly where the stock stereo mounts?
What year Max btw> I have a '98.. Oh, post some pics too of the install with the empeg removed to if possible.. Thanks.
John M
#70779 - 03/03/2002 20:57 Re: Fitting problems. [Re: jnmunsey]
MaximaJed
Well i kinda just bent the cage housing sorta. I would take a pic of that for you, but i would have to take out my dash again. But I'll snap some pics of the unit and the dash console without the rio in it tomorrow with my new CoolPix 995 camera
#70780 - 04/03/2002 08:51 Re: Fitting problems. [Re: MaximaJed]
MaximaJed
My measurements were off. Heres a pic of the whole unit installed.
75273-stereo 1.JPG (102 downloads)
#70781 - 04/03/2002 08:53 Re: Fitting problems. [Re: MaximaJed]
MaximaJed
Next pic is without the rio in and just the sled and my pioneer HU.
75274-stereo 3.JPG (137 downloads)
#70782 - 04/03/2002 08:54 Re: Fitting problems. [Re: MaximaJed]
MaximaJed
Final pic is one with both HU and rio running.
75275-stereo 7.JPG (146 downloads)
