Mark, here is the serial port log data post reboot:
Abnormal player termination
Player received signal 11
Starting player
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Loading dancefile: "/empeg/lib/visuals/princedance.raw "
! visual_Loading dancefile: "/empeg/lib/visuals/ymca.raw"
callback.cpp: 339:Failed to open file required by visuals library "/empeg/lib/vi
suals/breakdance.raw": No such file or directory
Loading dancefile: "/empeg/lib/visuals/topPoleSpin.raw"
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 7792
114, error=0xc0044000
The player runs fine until another KnobRight. Then you get this, looks like the serial port isn't fully restored right away and the first few lines are stuck in the buffer?
Restored terminal settings
No secondary hard disk
Starting player
Loading dancefile: "/empeg/lib/visuals/More Dancing.raw"
Loading dancefile: "/empeg/lib/visuals/breakdance.raw "
! visual_Loading dancefile: "/empeg/lib/visuals/newPoleDancer.raw"
suals/stonkdance.raw": No such file or directory
Vcb: 0x4086d000
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 6383
62, error=0xc0044000
Incidentally, stonkdance.raw is present in the /empeg/lib/visuals directory but I am still at v210.
Sorry about the time zone questions, just makes the [Hijack] offset problematic!
Lynn
