ok, i have searched the FAQ and the BBS thoughly, and i cant find an answer.
I have had my player back from support about a month and have just gotten my database to a healthy size. today i went through and cleaned up some and went to stab it back into the sled and after it booted there was no audio. The display suggests that everything is business as usual, but still no audio.
i brought the player back onto the house and hooked it up to my stereo, no audio.
I stressed out drank a beer and sat back to assess the situation.
so far i have:
I have tried to reboot it countless times, i have tried to reload the firmware (beta 11 in case anyone is intrested) and still i have no luck. I hope someone can offer some solutions, please. My worst fear is that the output chip is blown, or something horrific like that. i have not cracked the player open yet. i am hoping that it wont be nessissary. here is the boot log as well.
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg50 ([email protected]) (gcc versi
on 2.95.3 20010315 (release)) #8 Fri Feb 8 18:48:15 GMT 2002
Processor: Intel StrongARM-1100
empeg-car player (hardware revision 9, serial number 10101989)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg usb initialised, PDIUSBD12 id 0000
empeg state support initialised 0089/88c1 (save to d0004900).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-212000, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:c
5
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init player.cpp : 385:empeg-car 2.00-be
ta11 2002/02/08.
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
_______________________________________ former owner...now I'm just another schmuck
