Hi Rob,
>4. My LED's also stay lit after power down
That's a feature, which you can control in config.ini using the buttonled_off=n option in the [hijack] section.
I agree that the headlight sense is all futzed up at this point. For example, if your lights are already on when starting the car, the buttons come on at the "power down level". Most noticeable when using "buttonled_off=0" in config.ini.
Perhaps I'll fix that soon, I really haven't touched it since the initial implementation.
