How exactly will the dgital output board be mounted in relation to the red box depicted on your website diagram and where will the connector(s) emerge ? Will the case of the Empeg need to be cut for the output connector(s) or is the existing Empeg output connector used in some way ?
Once the digital output board is soldered into the Empeg, what is the impact on the normal Empeg output ? Can the Empeg still be used in the normal way, i.e. the internal DAC still works and the normal analogue output is still available or is it a case of digital output or normal analogue output, but not both ?
I was wondering if it is possible to use the Empeg in the home such that the digital output feeds an external DAC and yet the Empeg can still be used just as it always was in the car without an external DAC ? Basically the current sound quality is more than adequate for the car, but extra DAC quality would be welcome for my home system.
Andy [red] 60Gb Mk2a 030102939 [/red] [blue] 60Gb Mk2a 030102620 [/blue]
