If the problem isn't dimmer related, I suspect we'll have to get it back here and send out a replacement (so you're not mk2-less for long!).
The display PSU was a known issue with the mk1, which is why we totally redesigned it for the mk2 - and we've not seen any failures with our test units over the last 6 months or so.
Rob will contact you privately about how we work this swap!
Hugo
