I am trying to copy the Source button from the Rio remote to my Pronto. As this button works as a source switch with a short press and as the power switch with the long press, I wish to be able to send the long press so I can turn the Rio off(standby). I haven't been able to get this to work yet. When I "teach" the Pronto the source button it doesn't matter if I hold the button on the Rio long or short. It is learned as a short press and will only switch sources on the Rio. I'm sure that there is some hex code I could edit into the button code if I only knew what it was. The button codes as they come up in hijack don't look anything like the learned codes in the Pronto. I don't think this is unusual but it does make it more difficult to determine what is the correct code to enter to produce the results I'm looking for.
No matter where you might be, there you are.
